Proper uninstall program
shinji7800
shinji7800
Community Visitor
Community Visitor
I would like to have a full list of the modification of my os at this installation of fusion (folder created registry modification) to make a full clean uninstallation of the program
It is possible ?
Forgive my approximate English I'm French
Best regards
For a clean uninstall I would recommend uninstalling with something like Revo Uninstaller or a program of that sort.
It will look up all registry entries and have you delete them as well.
Alternatively you could also uninstall on the normal way and then use CCleaner to clean up the register.
After that you could do a search through your registry looking for everything under Autodesk. You'd probably get all the entries modified as well.
Keep in mind that working in the registry can compromise your systems integrity if you have no clue on how it works.
mdavis22569
