Problem of Installing AutoCAD 2017 on laptop
I am facing a problem of installing the AutoCAD software in my laptop. The setup keep initializing (as per below picture) but without any further response. Could I know what is the problem?
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
How did you install?  Using the install now option?
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
hello sir, i am also facing ploblem like this one . when i click on the run option ,it is buffering couple of minute and show me a eeror occured . as per the image posted below
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Mark.Lancaster
Your issue is related to >>this<<
If that doesn't resolve the issue see option #1 >>here<<
Also watch what you share.  Your image contains the serial number that was assigned to you.  Blur that info out before sharing.   I will have moderate remove your image to protect your sensitive info.
Mark Lancaster
