Prerequisites for AutoCAD 2022 Electrical not met
administratoren
Message 4 of 9
administratoren
Hello everyone,
I'm trying to install AutoCAD 2022 Electrical on an x64 Windows, with a 32-bit version of Office (can't change this, because it's a corporate environment) installed. Electrical asks for a 64-bit version of Access Database Engine. I installed this according to this manual https://knowledge.autodesk.com/de/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/DEU/H...
But the error still persists and the AutoCAD installer keeps saying, that ADE 2016 x64 is not installed. Does anyone have an idea how to fix this?
Replies (8)
Message 1 of 9
administratoren
Hello everyone,
Message 2 of 9
Valentin_CAD
@administratoren ,
Try:  Installation & Licensing Forum
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 9
administratoren
Thanks, I will post it over there.
Message 5 of 9
m_latz
Which Microsoft Office version have you installed ? 2013, 2016, 365 ?
Edit:
And can you please post a screenshot of the error you get.
regards
Markus
Message 6 of 9
administratoren
Office 2016 x86 is installed.
Here's a screenshot of the error generated by the installer ran in non-silent mode. Access Database Engine x64 is installed at this point, which also can be seen in the installed programs in Windows.
Ther error message basically says that the 64-bit version of Access Database Engine 2016 is required for the installation.
Message 7 of 9
m_latz
Okay, I will check it this evening ...
regards
Markus
Message 8 of 9
m_latz
Okay @administratoren ,
try the following:
regards
Markus
Message 9 of 9
administratoren
The installation completed without any errors now. I'm going to let the AutoCAD users test the application now.
Thanks.
