new installation 32bit DWG TrueView2017 English
I'm testing DWG TrueView2017 for my user.  I installed the 64bit version on my Windows 8.1 system and was able to use the product without error.   I installed the 32bit version on my users Windows 7 computer and received several errors, all similar, but maybe a different hexadecimal number.  If I click ok enough times, the .dwg file will open.  I've attached one  print screen of the errors.  I am interesting in a product to open .dwg files and wasn't sure of the limitations of the free product.   If there is an issue running it on Windows 7 computers or maybe I need to install a patch or a "full" version, please let me know.  Any help with this would appreciated.  Thanks and have a good day.
Rich
markcalloway
Hi
As for your error possibly an issue with your graphics drivers:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Except...
If your after a free viewer Autodesk also have the A360 Viewer which might be worth a quick look at if your trialing options:
https://a360.autodesk.com/viewer/
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Hi Mark,
Video card driver appears to have been the issue.   My problem was, I upgraded the BIOS and video card driver prior to installing True View.  I found I had to downgrade the driver to an older version from Dell or use the Windows driver version.
Thanks again,
Rich
