Need to add Revit 2018 to my network license file
RochesterIT
Message 1 of 8
RochesterIT
Revit 2018 is not listed for me to create a network license file including it along with the other applications. Any idea?
Replies (7)
Message 2 of 8
Mark.Lancaster
@RochesterIT
Are you the contract manager or software coordinator for your subscription?
To generate a license file (pick one)
1.  The contract manager or software coordinator for you subscription can log into their Autodesk Account and select Generate License file link
2.  Go to the Autodesk Register Once Web site and follow the prompts.  With Register Once you have to repeat the process for each network serial # that you have and then combine the license file at the end.
3.  Contact your reseller and they will do it for you.
4.  Contact Autodesk here and they will do it as well.
In all cases you will need the name and MAC address of the machine that is hosting the license file.   One final thing, you must update your license manager to version 11.13.1.2 (https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...)
Mark Lancaster
Message 3 of 8
RochesterIT
Yes I am both, and the only.
That is exactly what I have done and it's licensing fine. Why am I not able to see Revit in my products list like I can AutoCAD, 3dsmax, Inventor? Shouldn't I be able to generate a network file using the "Generate Network License File" from the All Products & Services page? I can see the others to add but not Revit. I have been able to do this in the past. In fact, Revit is not listed at all under All products and services.
Message 4 of 8
Mark.Lancaster
@RochesterIT
We are only users so we have no clue about your contracts and etc..  All I can think is Revit is on another contract and you are not the contract manager or software coordinator for that.  Do you have a reseller?  They can look this stuff up.  If you don't please chat with an Autodesk Agent >>here<<.
Mark Lancaster
Message 5 of 8
Mark.Lancaster
@RochesterIT
I just realized you are talking about educational software since you belong to a school.  This information would've helped if I knew that in the beginning..  Smiley Wink
Did you request Revit under your Educational account as a network license?
Mark Lancaster
Message 6 of 8
RochesterIT
Yes I did, that's how I got the increment and added it to the license file manually. I was just curious why it does not show up under All products like the rest, allowing me to use the tool to generate by selecting products. I was able to do this with the other products.
Maybe there is a delay before its added to my list?
Message 7 of 8
RochesterIT
This is Education. It's on no one else's contract. Ah well....
Message 8 of 8
RochesterIT
It finally showed up today with the others
