Missing Flexnet Service
I am missing the "Flexnet Licensing Service" service. I have the "Flexnet Licensing Service 64" service. Are there files I can download to resolve the issue?
Otto
Hello oldsimp
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
Can you post a screenshot of your error and where you get it?
Autodesk Forums:
Darin.Green
Welcome to the community, @Anonymous
The reason you don't have it is because you don't have any 32bit application that needs the 32bit flexnet engine. You can disregard not having it.
If this information was helpful, please consider using the Accept Solution
Darin.Green
In addition, if you're referring to the "Launching program results in Softlock License Manager error" then the licensing mechanism is screwed up which mean you'll need to perform a CLEAN UNINSTALL/REINSTALL.
Doing a clean uninstall of all Autodesk products.
shannon_e_wymer_ctr
Community Visitor
Community Visitor
Receiving the following error.  It's been years since i have messed with AutoCAD LM services, but it seems you may need the licensing service to be present in order to issues licenses. Please correct me if i am wrong.
