Maya Silent Install (Windows 10) Blocked by Autodesk Privacy Statement Modal Dialog
rick.shahid
rick.shahid
While silently installing Maya 2022 (or 2023) on Windows 10 with the --silent command line switch, the Autodesk Privacy Statement dialog (see attached snip) blocks the process completion. How can I enable acceptance of the privacy statement via a silent install process?
natasha.l
Hello @rick.shahid
The Privacy Statement message is prompted after first launch as it is a prerequisite for each user to decline or agree.
There is a community post on the subject "How to Suppress the AutoDesk Privacy Statement "
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
rick.shahid
Hi @natasha.l,
The privacy dialog is popping up during silent / automated installation and it is blocking the completion of the installation process since there is no logged in user. A silent installation should not create a blocking / modal dialog.
Is there any additional command-line switch that can be added to Setup.exe --silient to suppress / accept the privacy statement?
Thanks.
Rick
mdavis22569
@rick.shahid
Were you able to get this resolved?
Mike Davis
rick.shahid
@mdavis22569,
no, this is still an open issue.
mdavis22569
Hi
So I'd recommend putting in a ticket about this:
https://knowledge.autodesk.com/contact-support
Mike Davis
