Maya installation "Not enough disk space"
Just recently I've tried installing Maya. I use 3 Drives and my C drive (The default selected one for Maya) doesn't have enough disk space. I've tried sellecting my E and D drives as the installation directory. However whenever I press the install button it gives me an error saying my C drive doesn't have enough space.
After a brief research I've come across some other users with similar issues and tried the solution given to them and configure individual asset folders. But I get this screen and no loading happens.
Otto
Hello TailGunnner and welcome to the Autodesk community!
It looks like you're seeing the following error message during install: "Out of disk space". The following thread should help you resolve the problem:
Out of disk space during installation to another disk drive
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
dgorsman
Are you using one of the Install Now options, or have you downloaded the installer?
Specifically which of the options have you tried?  Have you started with the basics, like cleaning out trash, temp, hibernation, and useless content?
Typically what's happening is the contents of the installer are decompressed to a temp folder on your system drive (C:) before installing, so unless you redirect there it can easily run out of room.  Regardless of where that temp folder is located though, the major system components will still need to reside on the system drive.  If I'm reading that right and you have only ~2 GB free space on a ~55 GB drive that's *really* short of space.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
