Maya 2016 - Freezes when selecting objects
I'm having a problem where selecting a mesh of around 50k or higher with my select tool it causes my maya to freeze for a bit, is there a way to optimize this?
But, when i select objects using the outliner there is no freezes, is this a bug?
dembkod
kinyoshira
Hello. I know this reply is older, but I wanted to reach out anyway. This could be an install issue, I suppose. If a component is not loaded correctly it could be causing grief. On this forum, I think the best I can suggest is to uninstall the program, then uninstall the C++ redistributables from the machine. After this, reboot and then reinstall Maya and retest.
You could also update your graphics card drivers, this can really help.
This will give you a clean install base. If the behavior persists, it could be an issue, but that would be better handled in the Maya forums.
Thank you for taking part in our community!
David Dembkoski
