LTU doesnt' work
LTU doesnt' work
Message 1 of 10
LTU doesnt' work
I need to transfert license from my old computer (I have access to it  ), but on new computer LTU doesn't work - nothing happens when I try to run it.
I found tip on forum to delete license files to get it running - didn't help.
Please advise.
Replies (9)
Message 2 of 10
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
What Autodesk product and version are you talking about?
What type of license do you have, student, perpetual, or subscription?
Mark Lancaster
Message 3 of 10
I have Auto Cad LT 2015, box version for 1 computer - no subscription.
Message 4 of 10
Mark.Lancaster
@Anonymous
Just install and activate on new machine.  Don't worry about the license transfer.  Each software has roughly 2 activation capabilities and if you ever end up reaching the max limit, you just contact Autodesk.
Mark Lancaster
Message 5 of 10
I did, but AutoCad won't run - is starts, but after loading screen just quit - no error message.
Message 6 of 10
Mark.Lancaster
@Anonymous
I would recommend that you perform a clean uninstall per these instructions.   NOTE: The information within the article is solely based on you performing a clean uninstall of all "core" Autodesk products on your machine.  In certain situations, you will most likely not be removing all of your Autodesk products to resolve a given issue.  If that's the case, you'll need to adjust those settings and locations within the article to make sure you are not impacting those other Autodesk products you plan on leaving on your machine.
I would also recommend to remove license information per this instructions.
Then install again..
Mark Lancaster
Message 7 of 10
Installing everything again helped, also I didn't have admin rights to do everything (company network limiatations).
Thanks for help !
Message 8 of 10
"contact Autodesk"?  hahahahah.  hilarious.  Totally impossible.  Can't be done.
Message 9 of 10
parts65WKJ
I upgraded my rig and non of my Autodesk products work. They all require reactivation as per Autodesk, They say that they will not supply re-activation codes for my old versions because I no not have a subscription any more. I have perpetual license, I own the software. They say that they will only supply new code for newest version ( 2021) that I do not use. Is there a way to transfer authorization info from versions 2013-2014-2015-2016-2017 from one computer to another. Or I am stuck using this software on an old slow machine, if I can get it running at all . Best to email reply x1@com or txt 845-786-0620. HELP
Message 10 of 10
pendean
Community Legend
Community Legend
@parts65WKJ No one here can change any of that. Sorry.
