Lt 2025 issues
Lt 2025 issues
RedClayAssociates
Lt 2025 issues
RedClayAssociates
After reinstalling the  window 11  24h2  update,      Acad LT 2025 wont open.   I uninstalled it and  tried to reinstall but it wont complete  the install due to   " the feature you are trying to use is on a network resource that is unavailable"   Have spent the last few hours trying track down the issue.
Tried installing  Microsoft .NET Host 8.0.0  and got nowhere.
Brock_Olly
Try:
1. Check for Residual Files
Navigate to the installation folder for AutoCAD LT 2025 (typically C:\Program Files\Autodesk\).
Delete any folders related to AutoCAD LT 2025.
Check C:\ProgramData\Autodesk\ and %AppData%\Autodesk for any leftover files and remove them.
2. Clear Windows Installer References
Download and run the Microsoft Install/Uninstall Troubleshooter (Download link ).
Use it to remove any leftover entries for AutoCAD LT 2025.
3. Clean the Windows Registry
Open regedit (Windows Registry Editor).
Search for and delete any entries related to AutoCAD LT 2025. Caution: Back up the registry before making changes.
4. Check Network Resource Path
If the error specifies a file path, ensure it exists or modify it:
Open regedit.
Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk.
Look for any path references to the installation directory and ensure they are correct.
RedClayAssociates
Problem seems to be fixed
I downloaded and used the Microsoft Program Install Uninstall Troubleshooter
I used it to remove the .Net-Host-8.0.0-win-x64   and  reinstalled    ASP.NET Core Runtime 8.0.6 ,  Next,   .Net Desktop Runtime 8.0.6    Last .NET Runtime 8.0.6
and that allowed the Autocad Lt 2025 installation to complete without getting the dotnet -host error message
handjonathan
Glad to see you got it all sorted @RedClayAssociates
Jonathan Hand
Technical Marketing Manager | Construction
