I installed AutoCAD 2021, Architecture 2021, Revit 2021, and Inventor2021 for Windows 10 and Maya 2020 for MacOS using license manager, but I forgot to set the port for the license file and now it's conflicting with another application in our network.
After researching, I can update the license file on the license server with the free port that I can use, but I can't find the licpath.lic file on the end computer to update the path. This KB shows the location for version 2017 or highter, but it's incorrect. I don't see it in my machine, and I am running Windows 10 version 1909
"On Windows:
- For Autodesk software version 2017 and higher, LICPATH.lic file can be found in C:\ProgramData\Autodesk\CLM\LGS\<Product Key>_<Product version>.0.0.F. For example for AutoCAD 2019, the file location would be C:\ProgramData\Autodesk\CLM\LGS\001K1_2019.0.0.F"
I have also looked into Program Files, Program Files (x86). I found the licpath.lic for AutoCAD 2021, but does this apply to other applications such as Architecture, Revit, and Inventor? Is there a licpath.lic file that points the license path for all Autodesk applications?
Thank you very much for your help, please let me know if you have any questions.
Thank you,
Nhan
