Inventor update and uninstall issues
After installing Autodesk Inventor 2020, I tried to install the 2020.2 Update. During the update process a window poped up with "The feature you are trying to use is on a network resource that is unavailable." (see screenshot), probably searching for the Inventor setup file. After I found the file, the update was successfully installed. Luckily, after the issue described below, I didn't delete the setup files.
The last time I saw this window was when I tried to uninstall Inventor 2018 with Autodesk Uninstall Tool. The window poped up when the Tool was uninstalling Inventor 2018 (other products seemed to be uninstalled correctly). So, I had to use windows tools and CCleaner to clear the rest of files.
Does these issues mean that I must not delete setup files (8 GB) in order to update and uninstall Inventor products correctly?
My OS is Windows 7 SP1 (x64)
When you originally installed Inventor, did you change the default location of where the install files are stored (C:\Autodesk\WI)? When you install updates, they modify the existing installation and look to the default location, if you have moved it somewhere else, you will need to specify the location.
Also, Nightwish is a great band.
mdavis22569
Hi @Anonymous
Unfortunately no ... Autodesk products from time to time need the original installation files / MSI's ...
So you'll want to download / extract it again. From the you'll want to run the update again.
Have you tried downloading the update itself and not from the Autodesk Desktop App?
Mike Davis
