Inventor CAM 2020 - Addin will only obtain license when run as administrator
tdswanson
tdswanson
I've recently installed Inventor 2020 and subsequently Inventor Cam 2020.
I happen to be the IT guy here at our small shop, so I'm a full administrator on this local machine as well as the domain.  I had no issues getting Inventor activated and run.
However, the only way I can get the Cam addin to license is if I right click on the Inventor shortcut and choose "Run as Administrator".  I have done the following:
  • Repair installation on Inventor CAM – No change
  • Reinstall Inventor CAM – No Change
  • Remove Inventor CAM, Reboot, Install Inventor CAM – No Change
  • Uninstall Inventor CAM, Uninstall Inventor 2020, Reboot, Install Inventor, Reboot, Launch Inventor, Update Inventor, Reboot, Install Inventor CAM – No Change
Anyone else run into this or have any tips?  I have a ticket open with AutoDesk, but their last suggestion was just to keep launching the software by right clicking as described above.
Thanks!
Mark.Lancaster
See this posting and solution https://forums.autodesk.com/t5/inventor-forum/fix-cam-2020-to-work-with-all-network-users-of-invento...
Mark Lancaster
tdswanson
Thank you, this worked!
