Inventor 2017 Initialization Error
After downloading Inventor 2017, or any available year of Inventor, I run the install file and as soon as it begins to initialize I get the error shown in the screenshot.
My computer specs are shown in the screenshots below as well.
Ryan
Mark.Lancaster
@Anonymous
See my reply here: https://forums.autodesk.com/t5/installation-licensing/problemas-al-instalar/td-p/8042984
Also installation (and licensing) issue should always be posted in the Installation and Licensing forum and not here https://forums.autodesk.com/t5/installation-licensing/bd-p/24 (even though its an installation issue for Inventor).  I will have the moderator relocate it there to better suit your needs.  In addition as indicated in that other posting..  Watch what you're sharing..  Your image contains the serial # that was assigned to you.  I will also ask the moderator to remove your image to protect your sensitive info.
Please disregard my info about sharing sensitive info..  I thought your image did contain it..  (My bad).
Mark Lancaster
Thank you, I did that quickly and didn't realize. And my apologies regarding which forum this should have been in, I didn't see the option for an Installation and Licensing forum.
Not a problem, you had me convinced.
@Mark.Lancaster wrote:
@Anonymous
