Inventor 2016
Inventor 2016
Inventor 2016
I am trying to download Inventor 2016 but it will not download. I am a Engineering student and it is required for my class. I am running 64 bit version of windows 10. I have attached a screen shot as well as the Log.
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Mark.Lancaster
@Anonymous
Welcome to the community...
Your download is failing due to the method you're using..
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
