Announcements
Inventor 2016 PRDSU - Cannot find cab file
I've downloaded the 2016 PRDSU files using the dl manager.  Attempted to install & the installer gets part way through & throws the attached error.
The file it looks for is in the correct position as per 2nd screenshot.
Any ideas on what I can do to get this installed??
Anti virus is off.  Run the setup as admin.  Windows temp files cleared prior to install.
BW
ukdxb012
What happens if you try to retry? Have you tried running the MSI in the location? Does it allow you to install?
You could follow the uninstall/reinstall instructions for an earlier library, see if that works... http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Install of the msi ends up with the same error unfortunately.
ukdxb012
Instead of using Download Manager, may i suggest you use the Browser Download option.
Duncan Brannan
Twitter | LinkedIn
Yes, I may try that but I fear my internet connection (at least for the next few days) is flakey at best & won't be stable enough for the 33GB download.
Stay tuned....
ukdxb012
That could impact things if your internet is a little flakey as you say. Still worth a try downloading via browser download through the night rather than whilst your working.
Duncan Brannan
Twitter | LinkedIn
Media arrived today & installed fine.
