Installing AutoCAD LT 2014 without 360
Is there a way to install LT 2014 without Autodesk 360?   I can de-select the option in install config, but it still installs and places a shortcut on the desktop.  It seems to install during the step "AutoDesk Cloud Sync".
I can uninstall 360 afterwards, but this isn't really a great workaround.
Cheers,
Az.
DarrenP
you would have to edit the setup.ini in some way would be the only other way i can think of
DarrenP
JTBWorld
Change the below line in the ini file is the only option unless you uninstall 360 after:
POSTREQUISITE=ACAD_PSPACK;ADSYNC;ACADSKETCHUPIMPORT
to
POSTREQUISITE=ACAD_PSPACK;ACADSKETCHUPIMPORT
I've also documented the problem here.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
That works nicely, thanks very much!
Can you verify if AutoCAD is stable with this install change? Is anyone having problems by not having 360?
DarrenP
i'm not been running without it for a few months
DarrenP
