Installing 2021
Installing 2021
igoodwin
Message 1 of 9
Installing 2021
igoodwin
Has any one out there had an issue with their Office products not running after installing Inventor 2021?  I've have tried uninstalling Office and then reinstalling but it didnt help.
Replies (8)
Message 2 of 9
mdavis22569
@johnsonshiue
Is there anything for an AKN about this?  I've seen this about 10 times ...
@igoodwin  most have had to clean install Office again... But from what you mention that's not working ..
Mike Davis
Message 3 of 9
igoodwin
Thanks for your reply.
Inventor 2021 installation was fantastic.....installed with no issues. Only when I tried to open Outlook 2016 and Access 2016 as we have a database for our production I ran into problems.
I then tried to uninstall office and reinstalled it.....Outlook now opening but Access still has the same error issues.
Stay Safe.
Regards
Iain
Message 4 of 9
mdavis22569
I've seen this. But not the Access not working after. Especially since 2021 doesn't use Access anymore. Not sure why it would keep that one corrupted.
Mike Davis
Message 5 of 9
DannyHubbard
Inventor 2021 does still install a Microsoft Access database engine, which is 64-bit. If you have a 32-bit Office install it can cause a conflict. The following document should help you get a Access running again without error.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-i...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 6 of 9
mdavis22569
 I thought Inventor 2021 wasn't using Access ...etc
I know if you go to export a BOM / Parts list now, the option to do it to Access has been removed.
Mike Davis
Message 7 of 9
DarrenP
this is the first i heard of Inventor 2021 causing this
i know Electrical 2021 can cause this error
DarrenP
Message 8 of 9
DannyHubbard
The older Access formats were removed because of some security issues. The Access Database Engine is still used for the Electrical Catalog Browser in Inventor.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 9 of 9
igoodwin
Hi Danny...Many thanks for your sugguestion.  It worked very well....renamed the 64 bit Access DLL File  in the registry.  Job done.  Cheers  Iain
