Installation Process For AutoCAD Map 3D 2019 Crashes
I am able to successfully download the .exe file but when the installation process begins the program suddenly crashes. After the self-extract portion finishes the Autodesk Geniune Service - Installshield Wizard appears on the taskbar (see attached screenshot) for approximately 10 seconds then disappears and nothing else happens. I have tried other versions and on other computers and I still have the same problem happening. I am running Windows 7 64-bit.
mdavis22569
Not sure where you're getting that download ....but try this one from AVA ( Autodesk Virtual Agent)
https://ava.autodesk.com/
https://efulfillment.autodesk.com/NetSWDLD/2019/MAP/65582774-92FC-47A0-8E89-3FF9BCF745EA/SFX/Autodes...
Mike Davis
Thank you!!!  This worked perfectly.
mdavis22569
Awesome ....glad I could help!
Mike Davis
