Installation problem
Trying to install free student version of AutoCad and this error occoured
ennujozlagam
@Anonymous hello, you can try this, you need to download from autodesk virtual agent and try to switch off all your anti virus program and firewall, you must need direct connection to the internet dont use wifi. thanks
Autodesk virtual agent HERE
TravisNave
There's nothing in your message. Can you attach your installation log file?
Thanks.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
