Installation is failed when trying to install with .ini file
Hi Team,
I have tried installing the Autoedsk inventor application using the below command line.
"Path of the setup.exe" /w /q /l "Path of the .ini file".
If i try to install the application with the same command line in the clean machine (vmware test machine) it is installing fine.
But when i try to install in my local machine it is failing mean to say not installing all the products installing only the Autodesk Revit interoperability and desktop center libraries.
I have to deploy it for the 40 users using the deployment tool.
When i use the commands in the sccm and sms.txt it is installing but the license is not getting applied to the inventor .
I have VC++ 2005, 2008, 2010, 2012 and Dot net framework 4.5 in my local machine. Can some one tell me whether do i need to do some changes to the ini file or Please share me the ini file which works properly if the applications VC++ 2005, 2008, 2010, 2012 and Dot net framework 4.5 there in the machine.
Could someone please help me out how to solve this issue?
