Installation error
Installation error
Installation error
Hi guys
I have some kind a problem here, I'm trying to install Autocad and i get the error 1603.
Already check the LOG file and I can't find any clue about this error, I try to install in English and in Portuguese, the same error appears.
I'm remove all C++ and .Net from this machine, try to reinstall and the same error appears again
I send here the LOG file, if anyone can help me with that.
S.Faris
Hi @S.Faris , thanks for you help.
None of this options works, maybe it's a OS problem, I will format that computer.
mdavis22569
Make sure you have all of the Windows updates installed ....
Seeing this issue quite a bit ....   Supposedly the Autodesk Installation / Licensing people are monitoring this page for 2020 issues ... but I've yet to see anyone posting or helping with resolving issues. Most often a support case needs to  be made / submitted.
It took 3 hours or remoting for a buddies to get resolved for this ...
Mike Davis
TravisNave
It's likely failing for the same reason Autodesk products always fail in your case.  You have a space in your username.  For some reason, this always seems to break Autodesk installers.  If you login as the local Administrator account, or create a new account without spaces and install that way, it's possible that it will install.  Otherwise, you need to change all of your user environment variable paths for %TEMP% and redirect your Documents to a path without spaces.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
