Announcements
Installation Error for Inventor 2025
michaelspace
Message 1 of 12
michaelspace
Just downloaded and am trying to install Inventor 2025.  It keeps failing and this is the error in the log file.
2024-03-27T16:20:51.682 [Deployment: 17264, single] [Space7760-06 ERROR] 1603: Fatal error during installation.
2024-03-27T16:20:53.413 [Deployment: 17264, single] [Space7760-06 ERROR] {DEEC1ED7-6122-3BB9-84C1-230CF1AFB7A9} : 1603
2024-03-27T16:20:53.413 [Deployment: 17264, single] [Space7760-06 ERROR] Deployment failed!
2024-03-27T16:20:53.414 [Deployment: 17264, single] [Space7760-06 INFO] Error context: Action start 16:20:51: UninstallPreviousVersions. UninstallPreviousVersions: Found adsk_hive_host.exe process id: 9496 UninstallPreviousVersions: Failed to open process for pid(9496) UninstallPreviousVersions: Deprecated Hive version is running then terminate the installation process CustomAction UninstallPreviousVersions returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox) Action ended 16:20:51: UninstallPreviousVersions. Return value 3. Action ended 16:20:51: INSTALL. Return value 3. Property(S): UpgradeCode = {D8B2D6FC-CAAC-4B17-9FA0-9B223BDBC57C} Property(S): WIXUI_INSTALLDIR = INSTALL_ROOT Property(S): ARPNOMODIFY = yes Property(S): CommonFiles64Folder = C:\Program Files\Common Files\ Property(S): ALLUSERS = 1
2024-03-27T16:20:53.414 [Deployment: 17264, single] [Space7760-06 INFO] Please explore possible solution from: https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-relea...
What is it trying to uninstall and why?
Replies (11)
Message 2 of 12
mdavis22569
Try using this not the deployment:
p1:
https://efulfillment.autodesk.com/NetSWDLD/ODIS/prd/2025/INVPROSA/E578CB4E-CF55-3E4D-9A8A-213245140B...
p2:
Mike Davis
Message 3 of 12
michaelspace
What I ended up finding was that the "Autodesk Hive" process was running in the background and was creating a problem with the 2025 installer of the same name.  I had to kill the running "Hive" process so the new one could then install and not cause a failure in the entire installation.
We found the same thing on a co-workers PC so it wasn't a one-off.
Message 4 of 12
DarrenP
also ran into this error with 2 other 2025 products
DarrenP
Message 5 of 12
michaelspace
Sorry, I should have mentioned that.
I had the same thing with AutoCAD Electrical as well.
Message 6 of 12
Darin.Green
I ran install into the same issue.  To fix the issue, Uninstall Autodesk Interoperability Engine Manager (all versions if necessary).  Run the Autodesk Installation again, or install the Interoperability Engine from [InstallMedia]/x64/HIVE/adsk-hive-host
That should resolve the issue.
If this information was helpful, please consider using the Accept Solution
Message 7 of 12
DarrenP
Weird thing is what is causing it to fail
This doesn’t seem to happen with a specific product
I installed multiple 2025 products only 2 of them failed with this same error while the others installed fine
DarrenP
Message 8 of 12
mdavis22569
Odd I haven't seen that reported yet ...
Mike Davis
Message 9 of 12
DarrenP
Since 2025 just came out
You will probably get more reports in the coming days
DarrenP
Message 10 of 12
mdavis22569
I have seen this one:  adsk-hive-host
Mike Davis
Message 11 of 12
bas.claassen
Looks like the links above to the full installer are working but the install from manage.autodesk.com is returning into a 1603 error.
Message 12 of 12
mdavis22569
Odd I just used it .. without an issue.
I'd look at deleting you can in your C:\Autodesk for this installer.
Delete the ones in your C:\download
Delete everything you can in your %temp% folder.
Re-download BOTH parts.
Make sure you have Admin rights.  Anti-Virus off.
Mike Davis
