Install errors
Install errors
Message 1 of 17
Install errors
Hi All,
I did a little searching around the board and saw that I'm not the only person having the infamous C++ error. However, when I tried to download via the virtual agent, as suggested, I got the Autodesk Self Extract. When I try to extract, I now get an error that says "Product download consists of multiple files. At least one file is missing or has not been downloaded yet." Any suggestions?
Replies (16)
Message 2 of 17
Otto
Hello robert.maher_iii and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software. You can download software from our Virtual Agent (click on Download Links, choose product and version). Please disable your firewall and anti-virus programs before downloading.
Also, other community members with similar questions found the following articles useful:
Previous Versions of Autodesk Software
Download Methods
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 17
I can download it just fine, I'm just having trouble extracting it
Message 4 of 17
Have you tried to install it from the autodesk app in the taskbar? It worked for me when my install failed.
Message 5 of 17
What do you mean by taskbar? I don't have an Autodesk app on my taskbar.
Message 6 of 17
The autodesk utility AutodeskdesktopApp.exe that installs with Maya. It's
linked to your account and sends you information about updates and new
versions etc
Message 7 of 17
versions etc
Message 8 of 17
Maybe I did the whole install wrong then, because I don't have that in my File Explorer. Can you walk me through it?
Message 9 of 17
Message 10 of 17
Message 11 of 17
Will this work even if I have a student account?
Message 12 of 17
I'm not sure if it is available to the student version. That could be
the reason you do not have it by default.
You could also try and delete the maya install folder in the temp
directory and force a full reinstall. (I was able to get past the c++
redist error that way)
Message 13 of 17
Message 14 of 17
So I think I installed it, but I still can't find it on my File Explorer
Message 15 of 17
If you are using windows 10 then pull up the taskbar and type in app. it
should be among the found applications.
Message 16 of 17
Message 17 of 17
Sorry, I meant I installed 3dsmax. I was able to get the desktop app easily and install 3dsmax, I think, but now I can't find 3dsmax
