Install Error
I can not install the trial version of autocad. Errorcode 0 keeps popping up.
This is the setup log
[8/10/2019, 19:16:23] === Logging started: 2019/08/10 19:16:23 ===
[8/10/2019, 19:16:23] Executable: C:\Users\user\Downloads\dotNetFx45_Full_setup.exe v4.5.50709.17929
[8/10/2019, 19:16:23] --- logging level: standard ---
[8/10/2019, 19:16:23] Successfully bound to the ClusApi.dll
[8/10/2019, 19:16:23] Error 0x800706d9: Failed to open the current cluster
[8/10/2019, 19:16:23] Cluster drive map: ''
[8/10/2019, 19:16:23] Considering drive: 'C:\'...
[8/10/2019, 19:16:23] Considering drive: 'D:\'...
[8/10/2019, 19:16:23] Drive 'D:\' is rejected because of the unknown or unsuitable drive type
[8/10/2019, 19:16:23] Drive 'C:\' has been selected as the largest fixed drive
[8/10/2019, 19:16:23] Directory 'C:\1994545832fed0b24d0b\' has been selected for file extraction
[8/10/2019, 19:16:23] Extracting files to: C:\1994545832fed0b24d0b\
[8/10/2019, 19:16:24] Extraction took 313 milliseconds
[8/10/2019, 19:16:24] Executing command line: 'C:\1994545832fed0b24d0b\\Setup.exe /x86 /x64 /web'
[8/10/2019, 19:16:35] Exiting with result code: 0x0
[8/10/2019, 19:16:35] === Logging stopped: 2019/08/10 19:16:35 ===
