Announcements
Infraworks 360 included with Subscription
sureshchotrani
Advisor Advisor
sureshchotrani
Am not getting, what benifits are there under Infraworks 360, does below says I have access to Infraworks 360. If yes then how?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
ukdxb012
You need to install Infraworks 360 from Autodesk Account. Simply ask the Contract Manager or Software Coordinator to give you access to Product Downloads or install via the Free Trial... http://www.autodesk.com/products/infraworks-360/free-trial
It would appear from your screenshot that the Contract Manager or Software Coordinator has already assigned Infraworks 360 to your Autodesk ID. You now need an install/instance on your machine of Infraworks 360 to progress. Once you have the install, you can login to Infraworks via your Autodesk ID.
What benefits are you referring to exactly? What were you expecting?
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
sureshchotrani
I want to use Infraworks 360 software.
I have already used trail version for 1 month.
When I click access it takes me to Infraworks 360 page for trail.
ukdxb012
Now that you have used the 30 day trial, the only option you have is to buy or rent the software. You cannot keep reactivativating trials unfortunately.
If you're a student, you could apply for a 3 year educational license but you need a valid higher education email address.
Duncan Brannan
Twitter | LinkedIn
