Hello everyone,
Another infamous Revit 2018 install failure here, our typical 1603 is back.
I've had enough of these to know the do the following:
- Uninstall Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.242.10
- Uninstall Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.242.10
- Run Microsoft .NET Framework Repair Tool from https://www.microsoft.com/en-us/download/details.aspx?id=30135
This time though, even after doing the above I was still getting 1603 / 1619 errors
So after digging through the forums, I did the following:
- Uninstall everything (AutoCAD, A360, Desktop Application...)
- Removed all folders AutoDesk related from:
-- C > Autodesk
-- C > Program Files > Autodesk
-- C > Program Files (x86) > Autodesk
-- C > Temp > Autodesk stuff
- Ensured the Temp folder existed but empty
Still getting 1603 errors, so I did a Virtual Agent install.
This time it 'installed', but when I tried to open the application it would crash.
When I sent the crash report, it asked me to install the hotfix.
After installing the hotfix, Revit would still crash.
Now some notable points about the Virtual Agent install.
- It installed Revit 2018.1 (never saw the .1 before)
- I noticed it also installed Dynamo when I was looking at the prompts (cool! I didn't ask for it but was going to do it after)
- I saw the Virtual Agent gave me Part 1, Part 2, and Part 3.
-- I downloaded all parts, and ran Part 1, and it looked it Revit 'installed' everything. (therefore did not run Part 2 and 3)
Questions Moving Forward:
1. Do I need to run Part 2 and Part 3 of the Virtual Agent install, even though Revit is 'installed' after Part 1
2. Do I need to uninstall everything again, and run a 'normal' install so you guys get the logs?
3. Worst case scenario, I would rather not flash my computer and do a complete reinstall of everything.
The software works great when it's first install! After that, well, upgrading has been a headache.
Looking forward to something, thanks for the work.
