The program appears to install properly but when I try to run the program, a window pops up saying:
"The program can't start because MSVCP140.dll is missing from your computer. Try reinstalling the program to fix this problem."
I have uninstalled and reinstalled this program several times, followed all the troubleshooting suggestions from the Autodesk help files and made sure that all the current windows updates are installed. The last part of the installation for the Eagle program indicated it was installing the Visual C++ 2015 Redistribution package. When I looked in the file listings for the installed files in the control panel, I did not see any listing for the Visual C++ 2015 Redistribution package. I went into the Eagle folder and tried to reinstall the vcredist_x64.exe file and it started to install then a message box popped up saying "A later version of Microsoft Visual C++ 2015 x64 Minimum Runtime - 14.0.24210 is already installed" It gave me an error code of 0x80070643 - Fatal error during installation.
I have also posted this problem on the Microsoft forums in case it may be a windows problem. So far all of the things they have suggested have not fixed the problem.
It also created a log file :
[1600:1668][2019-08-19T16:33:32]i001: Burn v3.7.3813.0, Windows v6.1 (Build 7601: Service Pack 1), path: C:\EAGLE 9.4.2\vcredist_x64.exe, cmdline: ''
[1600:1668][2019-08-19T16:33:32]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Owner\AppData\Local\Temp\dd_vcredist_amd64_20190819163332.log'
[1600:1668][2019-08-19T16:33:32]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\EAGLE 9.4.2\vcredist_x64.exe'
[1600:1668][2019-08-19T16:33:32]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\EAGLE 9.4.2\'
[1600:1668][2019-08-19T16:33:32]i000: Setting string variable 'WixBundleName' to value 'Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210'
[1600:1668][2019-08-19T16:33:32]i100: Detect begin, 10 packages
[1600:1668][2019-08-19T16:33:32]i000: Setting version variable 'windows_uCRT_DetectKey' to value '10.0.14393.2990'
[1600:1668][2019-08-19T16:33:32]i000: Setting numeric variable 'windows_uCRT_DetectKeyExists' to value 1
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.3 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.3 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.2 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.2 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.1 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.1 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to true.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.0 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i052: Condition '(VersionNT = v6.0 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[1600:1668][2019-08-19T16:33:32]i101: Detected package: vcRuntimeMinimum_x64, state: Absent, cached: Complete
[1600:1668][2019-08-19T16:33:32]i101: Detected package: vcRuntimeAdditional_x64, state: Absent, cached: Complete
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows81_x86, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows81_x64, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows8_x86, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows8_x64, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows7_MSU_x86, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: Windows7_MSU_x64, state: Present, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: WindowsVista_MSU_x86, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i101: Detected package: WindowsVista_MSU_x64, state: Absent, cached: None
[1600:1668][2019-08-19T16:33:32]i052: Condition 'VersionNT64 >= v6.0 OR (VersionNT64 = v5.2 AND ServicePackLevel >= 1)' evaluates to true.
[1600:1668][2019-08-19T16:33:32]i199: Detect complete, result: 0x0
[1600:1668][2019-08-19T16:33:36]i200: Plan begin, 10 packages, action: Install
[1600:1668][2019-08-19T16:33:36]i052: Condition '(VersionNT64)' evaluates to true.
[1600:1668][2019-08-19T16:33:36]i000: Setting string variable 'WixBundleRollbackLog_vcRuntimeMinimum_x64' to value 'C:\Users\Owner\AppData\Local\Temp\dd_vcredist_amd64_20190819163332_000_vcRuntimeMinimum_x64_rollback.log'
[1600:1668][2019-08-19T16:33:36]i000: Setting string variable 'WixBundleLog_vcRuntimeMinimum_x64' to value 'C:\Users\Owner\AppData\Local\Temp\dd_vcredist_amd64_20190819163332_000_vcRuntimeMinimum_x64.log'
[1600:1668][2019-08-19T16:33:36]i000: Setting string variable 'WixBundleRollbackLog_vcRuntimeAdditional_x64' to value 'C:\Users\Owner\AppData\Local\Temp\dd_vcredist_amd64_20190819163332_001_vcRuntimeAdditional_x64_rollback.log'
[1600:1668][2019-08-19T16:33:36]i000: Setting string variable 'WixBundleLog_vcRuntimeAdditional_x64' to value 'C:\Users\Owner\AppData\Local\Temp\dd_vcredist_amd64_20190819163332_001_vcRuntimeAdditional_x64.log'
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.3 AND NOT VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows81_x86
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.3 AND VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows81_x64
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.2 AND NOT VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows8_x86
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.2 AND VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows8_x64
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.1 AND NOT VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x86
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.1 AND VersionNT64' evaluates to true.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: Windows7_MSU_x64
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.0 AND NOT VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x86
[1600:1668][2019-08-19T16:33:36]i052: Condition 'VersionNT = v6.0 AND VersionNT64' evaluates to false.
[1600:1668][2019-08-19T16:33:36]w321: Skipping dependency registration on package with no dependency providers: WindowsVista_MSU_x64
[1600:1668][2019-08-19T16:33:36]i201: Planned package: vcRuntimeMinimum_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[1600:1668][2019-08-19T16:33:36]i201: Planned package: vcRuntimeAdditional_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows81_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows81_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows8_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows8_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows7_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: Windows7_MSU_x64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: WindowsVista_MSU_x86, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i201: Planned package: WindowsVista_MSU_x64, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1600:1668][2019-08-19T16:33:36]i299: Plan complete, result: 0x0
[1600:1668][2019-08-19T16:33:36]i300: Apply begin
[0D34:0DDC][2019-08-19T16:33:38]i360: Creating a system restore point.
[0D34:0DDC][2019-08-19T16:34:06]i361: Created a system restore point.
[0D34:0DDC][2019-08-19T16:34:06]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, options: 0x7, disable resume: No
[0D34:0DDC][2019-08-19T16:34:10]i000: Caching bundle from: 'C:\Users\Owner\AppData\Local\Temp\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}\.be\VC_redist.x64.exe' to: 'C:\ProgramData\Package Cache\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}\VC_redist.x64.exe'
[0D34:0DDC][2019-08-19T16:34:10]i320: Registering bundle dependency provider: {f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, version: 14.0.24210.0
[0D34:0DDC][2019-08-19T16:34:10]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, resume: Active, restart initiated: No, disable resume: No
[0D34:13B4][2019-08-19T16:34:10]i304: Verified existing payload: vcRuntimeMinimum_x64 at path: C:\ProgramData\Package Cache\{C0B2C673-ECAA-372D-94E5-E89440D087AD}v14.0.24210\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi.
[0D34:13B4][2019-08-19T16:34:10]i304: Verified existing payload: cab5046A8AB272BF37297BB7928664C9503 at path: C:\ProgramData\Package Cache\{C0B2C673-ECAA-372D-94E5-E89440D087AD}v14.0.24210\packages\vcRuntimeMinimum_amd64\cab1.cab.
[0D34:13B4][2019-08-19T16:34:10]i304: Verified existing payload: vcRuntimeAdditional_x64 at path: C:\ProgramData\Package Cache\{95265B86-188E-3F62-9CDB-60FCE59EC721}v14.0.24210\packages\vcRuntimeAdditional_amd64\vc_runtimeAdditional_x64.msi.
[0D34:13B4][2019-08-19T16:34:11]i304: Verified existing payload: cab2C04DDC374BD96EB5C8EB8208F2C7C92 at path: C:\ProgramData\Package Cache\{95265B86-188E-3F62-9CDB-60FCE59EC721}v14.0.24210\packages\vcRuntimeAdditional_amd64\cab1.cab.
[0D34:0DDC][2019-08-19T16:34:11]i301: Applying execute package: vcRuntimeMinimum_x64, action: Install, path: C:\ProgramData\Package Cache\{C0B2C673-ECAA-372D-94E5-E89440D087AD}v14.0.24210\packages\vcRuntimeMinimum_amd64\vc_runtimeMinimum_x64.msi, arguments: ' MSIFASTINSTALL="7" NOVSUI="1"'
[0D34:0DDC][2019-08-19T16:36:30]e000: Error 0x80070643: Failed to install MSI package.
[0D34:0DDC][2019-08-19T16:36:30]e000: Error 0x80070643: Failed to execute MSI package.
[1600:1668][2019-08-19T16:36:30]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[1600:1668][2019-08-19T16:36:30]i319: Applied execute package: vcRuntimeMinimum_x64, result: 0x80070643, restart: None
[1600:1668][2019-08-19T16:36:30]e000: Error 0x80070643: Failed to execute MSI package.
[0D34:0DDC][2019-08-19T16:36:30]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, resume: None, restart: None, disable resume: No
[0D34:0DDC][2019-08-19T16:36:30]i330: Removed bundle dependency provider: {f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}
[0D34:0DDC][2019-08-19T16:36:30]i352: Removing cached bundle: {f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, from path: C:\ProgramData\Package Cache\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}\
[0D34:0DDC][2019-08-19T16:36:30]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}, resume: None, restart initiated: No, disable resume: No
[1600:1668][2019-08-19T16:36:30]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Is there any other suggestions on what else to check to help make this work?
John
