@Anonymous
Welcome to the Autodesk User's Community..
Are you 100% sure it said that when it finished or that some products were unable to install? If you can't find it under Windows Control Panel/Programs than it didn't install.
However without your installation log file we can only speculate what the issue is at this point. So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
& Autodesk Services MarketPlace Provider
