I am having the hardest time getting AutoCAD working on my PC. (student)
mark_gamarnik
Observer Observer
Message 1 of 9
mark_gamarnik
Observer
Observer
I go to install AutoCAD 2026 for Windows once getting an educational license and every time I try to install I get this system pending restart error. I have gone through the knowledge base and troubleshooted each individual step and somehow eventually I was able to install. I've even completely removed my antivirus just incase. But now every single time I open up the program it freezes and I've gone through the steps as well too on the knowledge base article. Why does it keep freezing? My computer is strong enough to run the program well. Any suggestions?
Replies (8)
Message 2 of 9
ethanncollins93
That sounds frustrating, especially after finally getting it installed. The freezing is often caused by leftover files from the failed installs, graphics driver issues, or a corrupted user profile rather than system performance. Try updating your GPU drivers, running AutoCAD as administrator, and doing a clean reinstall using Autodesk’s Cleanup Tool. Also make sure Windows is fully updated and no restart is actually pending in the background, as that can still trigger instability.
Message 3 of 9
aisha_khann4422
Observer
Observer
When AutoCAD installs only after repeated attempts and then freezes on launch, it’s usually not a hardware problem but a corrupted install or system dependency.
A few things that commonly cause this:
  • A stuck Windows “pending restart” flag that wasn’t fully cleared
  • Leftover Autodesk services or licensing components from failed installs
  • Graphics driver issues (AutoCAD is very sensitive to GPU drivers)
What usually helps:
  • Fully restart Windows and make sure there are no pending updates
  • Use the Autodesk Uninstall Tool to remove all Autodesk components, then reinstall clean
  • Update or temporarily switch to the Microsoft basic display adapter to test if the GPU driver is causing the freeze
  • Run AutoCAD once as Administrator after reinstalling
If it still freezes after a clean reinstall, it’s best to contact Autodesk Education Support, as they can check licensing and install logs. This issue is very common and fixable, but it usually requires a truly clean reinstall.
Message 4 of 9
TheCADnoob
@mark_gamarnik wrote:
.... My computer is strong enough to run the program well...
Strong does not equate with compatible.
Have you checked your hardware against the certified devices?
https://www.autodesk.com/support/system-requirements/certified-graphics-hardware/autocad
CADnoob
Message 5 of 9
mark_gamarnik
Observer
Observer
I just did a complete uninstall using the knowledge base article. Followed it to a tee, and then did a reinstall and this time it did not say pending restart, so I proceeded to install it. I ran it for the first time and it started up saying sign in which I did and proceeded to do the same thing again as it froze. It seems to always start up but as soon as I try to click on something it freezes, or starts frozen immediately.
Message 6 of 9
mark_gamarnik
Observer
Observer
Still have same issue after a complete uninstall and reinstall. Have contacted support.
Message 7 of 9
mark_gamarnik
Observer
Observer
I have an Nvidia 3070 Ti which I understand is not on that chart. What does this mean, how can I get it to work then if I have no other computer?
Message 8 of 9
TheCADnoob
If its stalling at login you can try this:https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Access-ha...
Autodesk Access hangs or no response when trying to log in
Autodesk Support
Jan 24, 2025
Products and versions covered
Issue:
When trying to sign in to Autodesk Access the sign-in doesn't work properly and it hangs.
Causes:
Corrupted Autodesk Identity Manager component.
Solution:
Uninstall and Reinstall Autodesk Identity Manager:
  1. Go to Control Panel and open Programs and Features.
  2. Look for the "Autodesk Identity Manager" component and uninstall it.
  3. Reboot the system.
  4. Download and install the component from here.
Note. If the component doesn't show up in "Programs and Features", remove it by doing the following and then proceed with steps 3 and 4:
    1. Go to C:\Program Files\Autodesk\AdskIdentityManager.
    2. Right-click on "uninstall.exe".
    3. Run the file as Administrator.
Verify that WebView 2 component is installed
Reinstall Autodesk Access
    1. Reboot the system.
    2. Download and install the latest Autodesk Access version from here.
Set default browser:
  1. Click Windows icon and select Settings
  2. Click Application -> Default Application
  3. Set Microsoft Edge as the default Web Browser
CADnoob
Message 9 of 9
bhavani_sankuratri
Hello @mark_gamarnik ,
Did the information provided by @ethanncollins93 & @aisha_khann4422 and @TheCADnoob  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Bhavani Sankuratri | Community Manager
