How to Set up GPU rendering for 3ds max using Vray
We are going to buy a new workstation specifically for rendering purposes. How do we setup GPU rendering??? We are using 3ds max and our architect uses Vray renderer
DarrenP
i'm not a Vray user but V ray is a cpu & ram only renderer unless this has changed over the years
DarrenP
So there is no Vray Plugin to make use of GPU to render?
dgorsman
Correct.
Generically speaking GPU rendering isn't always the most cost-effective solution.  At smaller scales its usually cheaper to get a faster CPU, and/or one with more cores (or a motherboard that supports multiple processors), plus sufficient RAM, along with a CPU-based renderer.
DarrenP
probably a good question to post here: http://forums.chaosgroup.com/
DarrenP
