German Language Pack decompression empty folder
Bergkatze
Bergkatze
Hello, I try to decompress the German language pack for inventor 2016 and get an empty folder. I tried different downloads with different Systems (Win7 64Bit, Win 2008R2) with the same result. http://download.autodesk.com/us/support/files/inventor_2016_language_packs/Inventor_2016_German_Lang... After accepting the dialog window the "Autodesk Self Extract" closes itself after 2 seconds. Is the a different approach to decompress the files?
Bergkatze
FYI: I tried the French language pack http://download.autodesk.com/us/support/files/inventor_2016_language_packs/Inventor_2016_French_Lang... which decompresses correctly. The problem only exists with the german version of the language pack.
event viewer message for this process:
exception code: 0x40000015
error offset: 0x0004f66d
m_latz
I had the same problem. It looks like, that during the signing process from autodesk something went wrong. As workaround, create a certificate and sign it. Then the extract process works.
regards
Markus
Bergkatze
Thank you for the analysis of the problem. As I'm not a software developer I can't self-sign executables. I'm hoping that Autodesk will fix the download.
Bergkatze
Still got no response from Autodesk support.
A simple workaround for this expired Certificate is:
Set the clock to a date prior to 21st. The decompression works.
Martin_Langolf
Autodesk Support
Autodesk Support
Hi Bergkatze,
Thank you for making us aware of the found issue with the language pack for Inventor.
I forwarded this to our division, in order to amend the signature and can confirm that this is now resolved and a new version of the language pack has been re-published on the download website.
Hope this helps.
Cheers,
Martin
Martin Langolf
