Flow design won't install
Hi there, I was trying to install the free version of Flow Design but to no avail: The installer would download and the download configuration screen would work fine, but when I press "Install" it briefly (1 sec or less) shows the progress screen and then jumps to the failure to install screen... I have emptied the temporary folder and have the microsoft software needed. I am using Windows 7. Please let me know if you can help on this. I have pasted the installation log at the end of the message. Best regards, José Luis 2015/11/2:16:58:11 José Luis STALINGRAD === Setup started on STALINGRAD by José Luis === 2015/11/2:16:58:11 José Luis STALINGRAD Path_Length: 147 2015/11/2:16:58:11 José Luis STALINGRAD Current Directory C:\Autodesk\Flow_Design_2014_English_WIN_64bit_R3_wi_en-US 2015/11/2:16:58:11 José Luis STALINGRAD Launch 2015/11/2:16:58:11 José Luis STALINGRAD CommandLine /PK 961F1 /SN 900-65188723 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ADSKFD/WI/Flow_Design_2014_English_WIN_64bit_R3_wi_en-US... 2015/11/2:16:58:11 José Luis STALINGRAD Path_Length: 147 2015/11/2:16:58:11 José Luis STALINGRAD Current Directory C:\Users\JOSLUI~1\AppData\Local\Temp\_AI8F6A.tmp 2015/11/2:16:58:14 José Luis STALINGRAD === Setup ended === 2015/11/2:16:58:12 José Luis STALINGRAD === Setup started on STALINGRAD by José Luis === 2015/11/2:16:58:12 José Luis STALINGRAD Path_Length: 147 2015/11/2:16:58:12 José Luis STALINGRAD Current Directory C:\Users\JOSLUI~1\AppData\Local\Temp\_AI8F6A.tmp 2015/11/2:16:58:12 José Luis STALINGRAD Launch 2015/11/2:16:58:14 José Luis STALINGRAD Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ADSKFD/WI/{DE815472-71AA-4705-B781-2B706F3F05F5}/SETUP_x... 2015/11/2:16:58:14 José Luis STALINGRAD PageOpen LaunchDialog 2015/11/2:16:58:18 José Luis STALINGRAD PageOpen LicenseDialog 2015/11/2:16:58:18 José Luis STALINGRAD PageOpen ProductSelectionDialog2 2015/11/2:16:58:22 José Luis STALINGRAD PageOpen FullProgressDialog 2015/11/2:16:58:22 José Luis STALINGRAD Download Skipped VCREDIST2012x86 http://edutrial.autodesk.com/SWDLDNET3/2014/ADSKFD/WI/{DE815472-71AA-4705-B781-2B706F3F05F5}/VCREDIS... 2015/11/2:16:58:22 José Luis STALINGRAD Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Flow Design\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /q /norestart 2015/11/2:16:58:22 José Luis STALINGRAD Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=2
Otto
Hello CondorNegro and welcome to the Autodesk community!
It looks like you are seeing the following error: Error: Microsoft Visual C++ 2012 Redistributable (x86). The following article(s) should help you resolve the problem:
Error: "Microsoft Visual C++ 2012 install failed, Result=-2147024546"
Error installing Microsoft Visual C 2010 Redistributable package: Generic trust failure.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
