FlexNet Licensing error:-15,578. System Error: 10049 "WinSock: Invalid address"
nickchamberlainvideo
Message 1 of 8
Hey all, I've been attempting to install my Arnold license with Houdini and have had no luck so far. I've followed this: https://forums.autodesk.com/t5/installation-licensing/quick-start-guide-for-configuring-lmtools/m-p/...
But haven't been able to figure out what is going on. Looking at task manager I see lmgrd.exe running but no adskflex.exe
All help is appreciated, thanks!
Status
Flexible License Manager status on Sun 11/12/2017 15:56
[Detecting lmgrd processes...]
License server status: 27000@Nick-PC
License file(s) on Nick-PC: C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic:
Nick-PC: license server UP (MASTER) v11.13.1
Vendor daemon status (on Nick-PC):
adskflex: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: 192.168.1.3
License path: 27000@Nick-PC;
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Debug Log:
16:16:32 (lmgrd) -----------------------------------------------
16:16:32 (lmgrd)
16:16:32 (lmgrd)
16:16:32 (lmgrd) Server's System Date and Time: Sun Nov 12 2017 16:16:32 Pacific Standard Time
16:16:32 (lmgrd) pid 3352
16:16:32 (lmgrd) SLOG: Summary LOG statistics is enabled.
16:16:32 (lmgrd) Detecting other license server manager (lmgrd) processes...
16:16:32 (lmgrd) Done rereading
16:16:32 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on Nick-PC (IBM PC) (11/12/2017)
16:16:32 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
16:16:32 (lmgrd) World Wide Web: http://www.flexerasoftware.com
16:16:32 (lmgrd) License file(s): C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic
16:16:32 (lmgrd) lmgrd tcp-port 27000
16:16:32 (lmgrd) (@lmgrd-SLOG@) ===============================================
16:16:32 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
16:16:32 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sun Nov 12 2017 16:16:32 Pacific Standard Time
16:16:32 (lmgrd) (@lmgrd-SLOG@) PID: 3352
16:16:32 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
16:16:32 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
16:16:32 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
16:16:32 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
16:16:32 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
16:16:32 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
16:16:32 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic -l C:\Autodesk\Network License Manager\debug3.log -z -s
16:16:32 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic
16:16:32 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
16:16:32 (lmgrd) Starting vendor daemons ...
16:16:32 (lmgrd) Starting vendor daemon at port 2080
16:16:32 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:32 (lmgrd) Started adskflex (pid 15676)
16:16:32 (adskflex) Unable to initialize access to trusted storage: 1
16:16:32 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:32 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:32 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:16:32 (adskflex) SLOG: VM Status: 0
16:16:32 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:16:32 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:16:32 (adskflex) EXTERNAL FILTERS are OFF
16:16:32 (lmgrd) adskflex using TCP-port 0
16:16:32 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:16:32 (adskflex) tcp_s is bad!!! Exiting
16:16:32 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:16:37 (lmgrd) adskflex exited with status 28 (Communications error)
16:16:37 (lmgrd) Since this is an unknown status, license server
16:16:37 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:16:37 (lmgrd) Starting vendor daemon at port 2080
16:16:37 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:37 (lmgrd) REStarted adskflex (pid 2604)
16:16:37 (adskflex) Unable to initialize access to trusted storage: 1
16:16:37 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:37 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:37 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:16:38 (adskflex) SLOG: VM Status: 0
16:16:38 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:16:38 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:16:38 (adskflex) EXTERNAL FILTERS are OFF
16:16:38 (lmgrd) adskflex using TCP-port 0
16:16:38 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:16:38 (adskflex) tcp_s is bad!!! Exiting
16:16:38 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:16:43 (lmgrd) adskflex exited with status 28 (Communications error)
16:16:43 (lmgrd) Since this is an unknown status, license server
16:16:43 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:16:43 (lmgrd) Starting vendor daemon at port 2080
16:16:43 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:43 (lmgrd) REStarted adskflex (pid 13624)
16:16:43 (adskflex) Unable to initialize access to trusted storage: 1
16:16:43 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:43 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:43 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:16:43 (adskflex) SLOG: VM Status: 0
16:16:43 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:16:43 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:16:43 (adskflex) EXTERNAL FILTERS are OFF
16:16:43 (lmgrd) adskflex using TCP-port 0
16:16:43 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:16:43 (adskflex) tcp_s is bad!!! Exiting
16:16:43 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:16:48 (lmgrd) adskflex exited with status 28 (Communications error)
16:16:48 (lmgrd) Since this is an unknown status, license server
16:16:48 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:16:48 (lmgrd) Starting vendor daemon at port 2080
16:16:48 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:48 (lmgrd) REStarted adskflex (pid 5672)
16:16:48 (adskflex) Unable to initialize access to trusted storage: 1
16:16:48 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:48 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:48 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:16:49 (adskflex) SLOG: VM Status: 0
16:16:49 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:16:49 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:16:49 (adskflex) EXTERNAL FILTERS are OFF
16:16:49 (lmgrd) adskflex using TCP-port 0
16:16:49 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:16:49 (adskflex) tcp_s is bad!!! Exiting
16:16:49 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:16:54 (lmgrd) adskflex exited with status 28 (Communications error)
16:16:54 (lmgrd) Since this is an unknown status, license server
16:16:54 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:16:54 (lmgrd) Starting vendor daemon at port 2080
16:16:54 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:54 (lmgrd) REStarted adskflex (pid 5752)
16:16:54 (adskflex) Unable to initialize access to trusted storage: 1
16:16:54 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:54 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:54 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:16:54 (adskflex) SLOG: VM Status: 0
16:16:54 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:16:54 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:16:54 (adskflex) EXTERNAL FILTERS are OFF
16:16:54 (lmgrd) adskflex using TCP-port 0
16:16:54 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:16:54 (adskflex) tcp_s is bad!!! Exiting
16:16:54 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:16:59 (lmgrd) adskflex exited with status 28 (Communications error)
16:16:59 (lmgrd) Since this is an unknown status, license server
16:16:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:16:59 (lmgrd) Starting vendor daemon at port 2080
16:16:59 (lmgrd) Using vendor daemon port 2080 specified in license file
16:16:59 (lmgrd) REStarted adskflex (pid 4256)
16:16:59 (adskflex) Unable to initialize access to trusted storage: 1
16:16:59 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:16:59 (adskflex) SLOG: Summary LOG statistics is enabled.
16:16:59 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:00 (adskflex) SLOG: VM Status: 0
16:17:00 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:00 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:00 (adskflex) EXTERNAL FILTERS are OFF
16:17:00 (lmgrd) adskflex using TCP-port 0
16:17:00 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:00 (adskflex) tcp_s is bad!!! Exiting
16:17:00 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:05 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:05 (lmgrd) Since this is an unknown status, license server
16:17:05 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:17:05 (lmgrd) Starting vendor daemon at port 2080
16:17:05 (lmgrd) Using vendor daemon port 2080 specified in license file
16:17:05 (lmgrd) REStarted adskflex (pid 11260)
16:17:05 (adskflex) Unable to initialize access to trusted storage: 1
16:17:05 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:17:05 (adskflex) SLOG: Summary LOG statistics is enabled.
16:17:05 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:05 (adskflex) SLOG: VM Status: 0
16:17:05 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:05 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:05 (adskflex) EXTERNAL FILTERS are OFF
16:17:05 (lmgrd) adskflex using TCP-port 0
16:17:05 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:05 (adskflex) tcp_s is bad!!! Exiting
16:17:05 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:10 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:10 (lmgrd) Since this is an unknown status, license server
16:17:10 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:17:10 (lmgrd) Starting vendor daemon at port 2080
16:17:10 (lmgrd) Using vendor daemon port 2080 specified in license file
16:17:10 (lmgrd) REStarted adskflex (pid 1248)
16:17:10 (adskflex) Unable to initialize access to trusted storage: 1
16:17:10 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:17:10 (adskflex) SLOG: Summary LOG statistics is enabled.
16:17:10 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:11 (adskflex) SLOG: VM Status: 0
16:17:11 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:11 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:11 (adskflex) EXTERNAL FILTERS are OFF
16:17:11 (lmgrd) adskflex using TCP-port 0
16:17:11 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:11 (adskflex) tcp_s is bad!!! Exiting
16:17:11 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:16 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:16 (lmgrd) Since this is an unknown status, license server
16:17:16 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:17:16 (lmgrd) Starting vendor daemon at port 2080
16:17:16 (lmgrd) Using vendor daemon port 2080 specified in license file
16:17:16 (lmgrd) REStarted adskflex (pid 8440)
16:17:16 (adskflex) Unable to initialize access to trusted storage: 1
16:17:16 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:17:16 (adskflex) SLOG: Summary LOG statistics is enabled.
16:17:16 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:16 (adskflex) SLOG: VM Status: 0
16:17:16 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:16 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:16 (adskflex) EXTERNAL FILTERS are OFF
16:17:16 (lmgrd) adskflex using TCP-port 0
16:17:16 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:16 (adskflex) tcp_s is bad!!! Exiting
16:17:16 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:21 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:21 (lmgrd) Since this is an unknown status, license server
16:17:21 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:17:21 (lmgrd) Starting vendor daemon at port 2080
16:17:21 (lmgrd) Using vendor daemon port 2080 specified in license file
16:17:21 (lmgrd) REStarted adskflex (pid 15112)
16:17:21 (adskflex) Unable to initialize access to trusted storage: 1
16:17:21 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:17:21 (adskflex) SLOG: Summary LOG statistics is enabled.
16:17:21 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:22 (adskflex) SLOG: VM Status: 0
16:17:22 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:22 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:22 (adskflex) EXTERNAL FILTERS are OFF
16:17:22 (lmgrd) adskflex using TCP-port 0
16:17:22 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:22 (adskflex) tcp_s is bad!!! Exiting
16:17:22 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:27 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:27 (lmgrd) Since this is an unknown status, license server
16:17:27 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
16:17:27 (lmgrd) Starting vendor daemon at port 2080
16:17:27 (lmgrd) Using vendor daemon port 2080 specified in license file
16:17:27 (lmgrd) REStarted adskflex (pid 1904)
16:17:27 (adskflex) Unable to initialize access to trusted storage: 1
16:17:27 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
16:17:27 (adskflex) SLOG: Summary LOG statistics is enabled.
16:17:27 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
16:17:27 (adskflex) SLOG: VM Status: 0
16:17:27 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
16:17:27 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
16:17:27 (adskflex) EXTERNAL FILTERS are OFF
16:17:27 (lmgrd) adskflex using TCP-port 0
16:17:27 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
16:17:27 (adskflex) tcp_s is bad!!! Exiting
16:17:27 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
16:17:32 (lmgrd) adskflex exited with status 28 (Communications error)
16:17:32 (lmgrd) Please correct problem and restart daemons
Replies (7)
Message 2 of 8
natasha.l
Hello @nickchamberlainvideo,
Welcome.
I would try following the steps below & if you have any questions feel free to ask.
  1. Try taking a look at your license file verify the Host Name and Physical Address
  2. Also be sure your license file is correct, you can get a new one by Generate a Network License File in Autodesk Account or Requesting a Network License File. The top of the license file should look like this with VENDOR adskflex....port=2080.
 3. Make sure you meet the NLM requirements to Install & Configure it
 4. Then, on each Client computer at launch, specify a License Server "2080@ServerName"
 5. Be sure the NLM has been "Started"
Try these steps & let us know if you still have a problem & we can make more suggestions. Thanks for posting. Smiley Happy
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 8
Hi there, still no luck unfortunately.
When changing the environment variable it cannot seem to find the license server.
Current logs:
Status
Flexible License Manager status on Mon 11/13/2017 23:06
Error getting status: License server machine is down or not responding.
See the system administrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Hostname: 192.168.1.3
License path: 2080@Nick-PC;
FlexNet Licensing error:-96,491
23:06:41 (lmgrd) -----------------------------------------------
23:06:41 (lmgrd) Please Note:
23:06:41 (lmgrd)
23:06:41 (lmgrd) This log is intended for debug purposes only.
23:06:41 (lmgrd) In order to capture accurate license
23:06:41 (lmgrd) usage data into an organized repository,
23:06:41 (lmgrd) please enable report logging. Use Flexera Software LLC's
23:06:41 (lmgrd) software license administration solution,
23:06:41 (lmgrd) FlexNet Manager, to readily gain visibility
23:06:41 (lmgrd) into license usage data and to create
23:06:41 (lmgrd) insightful reports on critical information like
23:06:41 (lmgrd) license availability and usage. FlexNet Manager
23:06:41 (lmgrd) can be fully automated to run these reports on
23:06:41 (lmgrd) schedule and can be used to track license
23:06:41 (lmgrd) servers and usage across a heterogeneous
23:06:41 (lmgrd) network of servers including Windows NT, Linux
23:06:41 (lmgrd) and UNIX. Contact Flexera Software LLC at
23:06:41 (lmgrd) www.flexerasoftware.com for more details on how to
23:06:41 (lmgrd) obtain an evaluation copy of FlexNet Manager
23:06:41 (lmgrd) for your enterprise.
23:06:41 (lmgrd)
23:06:41 (lmgrd)
23:06:41 (lmgrd)
23:06:41 (lmgrd) Server's System Date and Time: Mon Nov 13 2017 23:06:41 Pacific Standard Time
23:06:41 (lmgrd) pid 13996
23:06:41 (lmgrd) SLOG: Summary LOG statistics is enabled.
23:06:41 (lmgrd) Detecting other license server manager (lmgrd) processes...
23:06:41 (lmgrd) Done rereading
23:06:41 (lmgrd) FlexNet Licensing (v11.13.1.2 build 173302 x64_n6) started on Nick-PC (IBM PC) (11/13/2017)
23:06:41 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
23:06:41 (lmgrd) World Wide Web: http://www.flexerasoftware.com
23:06:41 (lmgrd) License file(s): C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic
23:06:41 (lmgrd) lmgrd tcp-port 27000
23:06:41 (lmgrd) (@lmgrd-SLOG@) ===============================================
23:06:41 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
23:06:41 (lmgrd) (@lmgrd-SLOG@) Start-Date: Mon Nov 13 2017 23:06:41 Pacific Standard Time
23:06:41 (lmgrd) (@lmgrd-SLOG@) PID: 13996
23:06:41 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.2 build 173302 x64_n6 ( build 173302 (ipv6))
23:06:41 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
23:06:41 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
23:06:41 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
23:06:41 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
23:06:41 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
23:06:41 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic -l C:\Autodesk\Network License Manager\debug4.log -z -s
23:06:41 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Autodesk\Network License Manager\License\Nick-PCd8cb8a39c43b.lic
23:06:41 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-1024
23:06:41 (lmgrd) Starting vendor daemons ...
23:06:41 (lmgrd) Starting vendor daemon at port 2080
23:06:41 (lmgrd) Using vendor daemon port 2080 specified in license file
23:06:41 (lmgrd) Started adskflex (pid 11736)
23:06:41 (adskflex) Unable to initialize access to trusted storage: 1
23:06:41 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:06:41 (adskflex) SLOG: Summary LOG statistics is enabled.
23:06:41 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:06:41 (adskflex) SLOG: VM Status: 0
23:06:41 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:06:41 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:06:41 (adskflex) EXTERNAL FILTERS are OFF
23:06:41 (lmgrd) adskflex using TCP-port 0
23:06:41 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:06:41 (adskflex) tcp_s is bad!!! Exiting
23:06:41 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:06:46 (lmgrd) adskflex exited with status 28 (Communications error)
23:06:46 (lmgrd) Since this is an unknown status, license server
23:06:46 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:06:46 (lmgrd) Starting vendor daemon at port 2080
23:06:46 (lmgrd) Using vendor daemon port 2080 specified in license file
23:06:46 (lmgrd) REStarted adskflex (pid 11764)
23:06:46 (adskflex) Unable to initialize access to trusted storage: 1
23:06:46 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:06:46 (adskflex) SLOG: Summary LOG statistics is enabled.
23:06:46 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:06:47 (adskflex) SLOG: VM Status: 0
23:06:47 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:06:47 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:06:47 (adskflex) EXTERNAL FILTERS are OFF
23:06:47 (lmgrd) adskflex using TCP-port 0
23:06:47 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:06:47 (adskflex) tcp_s is bad!!! Exiting
23:06:47 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:06:52 (lmgrd) adskflex exited with status 28 (Communications error)
23:06:52 (lmgrd) Since this is an unknown status, license server
23:06:52 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:06:52 (lmgrd) Starting vendor daemon at port 2080
23:06:52 (lmgrd) Using vendor daemon port 2080 specified in license file
23:06:52 (lmgrd) REStarted adskflex (pid 13932)
23:06:52 (adskflex) Unable to initialize access to trusted storage: 1
23:06:52 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:06:52 (adskflex) SLOG: Summary LOG statistics is enabled.
23:06:52 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:06:52 (adskflex) SLOG: VM Status: 0
23:06:52 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:06:52 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:06:52 (adskflex) EXTERNAL FILTERS are OFF
23:06:52 (lmgrd) adskflex using TCP-port 0
23:06:52 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:06:52 (adskflex) tcp_s is bad!!! Exiting
23:06:52 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:06:57 (lmgrd) adskflex exited with status 28 (Communications error)
23:06:57 (lmgrd) Since this is an unknown status, license server
23:06:57 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:06:57 (lmgrd) Starting vendor daemon at port 2080
23:06:57 (lmgrd) Using vendor daemon port 2080 specified in license file
23:06:57 (lmgrd) REStarted adskflex (pid 12772)
23:06:57 (adskflex) Unable to initialize access to trusted storage: 1
23:06:57 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:06:58 (adskflex) SLOG: Summary LOG statistics is enabled.
23:06:58 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:06:58 (adskflex) SLOG: VM Status: 0
23:06:58 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:06:58 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:06:58 (adskflex) EXTERNAL FILTERS are OFF
23:06:58 (lmgrd) adskflex using TCP-port 0
23:06:58 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:06:58 (adskflex) tcp_s is bad!!! Exiting
23:06:58 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:03 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:03 (lmgrd) Since this is an unknown status, license server
23:07:03 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:03 (lmgrd) Starting vendor daemon at port 2080
23:07:03 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:03 (lmgrd) REStarted adskflex (pid 14080)
23:07:03 (adskflex) Unable to initialize access to trusted storage: 1
23:07:03 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:03 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:03 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:04 (adskflex) SLOG: VM Status: 0
23:07:04 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:04 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:04 (adskflex) EXTERNAL FILTERS are OFF
23:07:04 (lmgrd) adskflex using TCP-port 0
23:07:04 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:04 (adskflex) tcp_s is bad!!! Exiting
23:07:04 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:09 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:09 (lmgrd) Since this is an unknown status, license server
23:07:09 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:09 (lmgrd) Starting vendor daemon at port 2080
23:07:09 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:09 (lmgrd) REStarted adskflex (pid 13696)
23:07:09 (adskflex) Unable to initialize access to trusted storage: 1
23:07:09 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:09 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:09 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:09 (adskflex) SLOG: VM Status: 0
23:07:09 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:09 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:09 (adskflex) EXTERNAL FILTERS are OFF
23:07:09 (lmgrd) adskflex using TCP-port 0
23:07:09 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:09 (adskflex) tcp_s is bad!!! Exiting
23:07:09 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:14 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:14 (lmgrd) Since this is an unknown status, license server
23:07:14 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:14 (lmgrd) Starting vendor daemon at port 2080
23:07:14 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:14 (lmgrd) REStarted adskflex (pid 15368)
23:07:14 (adskflex) Unable to initialize access to trusted storage: 1
23:07:14 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:14 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:14 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:15 (adskflex) SLOG: VM Status: 0
23:07:15 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:15 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:15 (adskflex) EXTERNAL FILTERS are OFF
23:07:15 (lmgrd) adskflex using TCP-port 0
23:07:15 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:15 (adskflex) tcp_s is bad!!! Exiting
23:07:15 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:20 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:20 (lmgrd) Since this is an unknown status, license server
23:07:20 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:20 (lmgrd) Starting vendor daemon at port 2080
23:07:20 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:20 (lmgrd) REStarted adskflex (pid 9628)
23:07:20 (adskflex) Unable to initialize access to trusted storage: 1
23:07:20 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:20 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:20 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:20 (adskflex) SLOG: VM Status: 0
23:07:20 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:20 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:20 (adskflex) EXTERNAL FILTERS are OFF
23:07:20 (lmgrd) adskflex using TCP-port 0
23:07:20 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:20 (adskflex) tcp_s is bad!!! Exiting
23:07:20 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:25 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:25 (lmgrd) Since this is an unknown status, license server
23:07:25 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:25 (lmgrd) Starting vendor daemon at port 2080
23:07:25 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:25 (lmgrd) REStarted adskflex (pid 15164)
23:07:25 (adskflex) Unable to initialize access to trusted storage: 1
23:07:25 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:25 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:25 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:26 (adskflex) SLOG: VM Status: 0
23:07:26 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:26 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:26 (adskflex) EXTERNAL FILTERS are OFF
23:07:26 (lmgrd) adskflex using TCP-port 0
23:07:26 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:26 (adskflex) tcp_s is bad!!! Exiting
23:07:26 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:31 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:31 (lmgrd) Since this is an unknown status, license server
23:07:31 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:31 (lmgrd) Starting vendor daemon at port 2080
23:07:31 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:31 (lmgrd) REStarted adskflex (pid 13812)
23:07:31 (adskflex) Unable to initialize access to trusted storage: 1
23:07:31 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:31 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:31 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:31 (adskflex) SLOG: VM Status: 0
23:07:31 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:31 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:31 (adskflex) EXTERNAL FILTERS are OFF
23:07:31 (lmgrd) adskflex using TCP-port 0
23:07:31 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:31 (adskflex) tcp_s is bad!!! Exiting
23:07:31 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:36 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:36 (lmgrd) Since this is an unknown status, license server
23:07:36 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
23:07:36 (lmgrd) Starting vendor daemon at port 2080
23:07:36 (lmgrd) Using vendor daemon port 2080 specified in license file
23:07:36 (lmgrd) REStarted adskflex (pid 1568)
23:07:36 (adskflex) Unable to initialize access to trusted storage: 1
23:07:36 (adskflex) FlexNet Licensing version v11.13.1.2 build 173302 x64_n6
23:07:37 (adskflex) SLOG: Summary LOG statistics is enabled.
23:07:37 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
23:07:37 (adskflex) SLOG: VM Status: 0
23:07:37 (adskflex) SLOG: FNPLS-INTERNAL-CKPT2
23:07:37 (adskflex) Server started on Nick-PC for: 86985ARNOL_2018_0F
23:07:37 (adskflex) EXTERNAL FILTERS are OFF
23:07:37 (lmgrd) adskflex using TCP-port 0
23:07:37 (adskflex) SLOG: Statistics Log Frequency is 240 minute(s).
23:07:37 (adskflex) tcp_s is bad!!! Exiting
23:07:37 (adskflex) EXITING DUE TO SIGNAL 28 Exit reason 5
23:07:42 (lmgrd) adskflex exited with status 28 (Communications error)
23:07:42 (lmgrd) Please correct problem and restart daemons
Message 4 of 8
DannyNL
Just a shot in the dark; make sure the ports 2080 and 27000-27009 are not blocked by a firewall.
Message 5 of 8
I have tried turning off my firewalls and restarting the server and that didn't seem to work either
Message 6 of 8
natasha.l
Please try the following steps to check the server, NLM & the connectivity to & from the client to the server.
1. Make sure to verify that the server is up & the service is running:
  • Locate Lmtools  in C:\Autodesk \Network License Manager (folder)
  • Make sure the current version of Lmtools 11.13.1.2 is installed
  • Verify License File, MAC address & HostID with Lmtools System Settings Tab
  • Config Service Tab > Make sure files are pathed correctly (lmgrd.exe, Lic. File.lic, Debug.log) > Save Service button
  • Start/Stop/Reread Tab > Select FlexNet Service (should only be 1 Autodesk service) > Check Box Force Server Shutdown > Select Stop Server Button > Uncheck Box Force Server Shutdown > Start Server > Server Start Successful. (should appear below)
  • Verify users are getting licenses if not...continue
2. Then, also verify that client computers can connect to the server
  • When you are experiencing difficulty pulling licensing from the network server verify the connectivity to the server from the computer(s) as described below:
            Using Internet Explorer to check if the ports used for licensing are open
            Microsoft Internet Explorer. Type the following into the browser:
            http://your-server-name:2080
            http://your-server-name:27000
            The URL should  display something similar to the following:
             Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60
  • If you have a firewall between the license server(s) and the client computers, you need to open some TCP/IP ports on the server to relay license communication or due to other non-Autodesk Services.
            Open port 2080 for adskflex, and open ports 27000 through 27009 for lmgrd.
            Or Bind a port to the license file
3. Try to pull a license from the client computer
  • Test the client computer & try to pull a license
  • Go to LMtools Server Status Tab > Perform Status Enquiry & check the licenses pulled
Message 7 of 8
Turns out I had to remap my 2080 port and it works great now, thank you!!
Message 8 of 8
natasha.l
Of course! So happy to hear you figured this out with the communities support. We appreciate you returning to let us know this information helped you.
Thank you. :smileyhapp:
