Fedora 43 Maya 2026 install problem
harryteasley
Observer Observer
harryteasley
Observer
Observer
Would anyone be able to help me out? The install keeps failing on my Fedora 43 laptop with Error 1. The error that I see in the console is "UPI Config file /home/XXXXXXXX/Downloads/Autodesk_Maya_2026_3_Update_Linux_64bit/ODIS/CER/upiconfig_lin.xml does not exist" Sure enough, it does not exist.
I'm running "./Setup" and get the admin password prompt near the beginning of the install. I can't run "sudo ./Setup" as the installer just comes up black in that instance, and sits there.
Any help would be appreciated. Fedora 43 on Framework 13 laptop, 32GB ram, Ryzen 9 HX 370 cpu
themitosan
Community Visitor
Community Visitor
I'm also running fedora 43 and I have the same issue
cbernier9
Community Visitor
Community Visitor
Same here, Fedora 43 on a Zephyrus G14 2021, same problem.
