fatal error: unhandled delayload " AcWebView.dll" module not found at 90B74F38h
vyankov
vyankov
Hi everyone,
I have some problem with instalation fo Autocad 2023...
After succefully installlation, i can't open anythink and thw folowing Fatal error is appear
"Fatal error: unhandled delayload " AcWebView.dll" module not found at 90B74F38h"
Can you help me
pendean
Community Legend
Community Legend
james.jinan.xue
Hi, @vyankov
Could you check the operating system version of your machine?
The operating system requirement of AutoCAD 2023 including Specialized Toolsets (Windows) is "64-bit Microsoft® Windows® 11 and Windows 10 version 1809 or above."
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
thegrob
I am having the same problem. I am trying to install on Windows 7. I changed minversion to 6.1.7601 in setup.xml, since I saw in a forum that that worked for AutoCAD 2022. I suspect that it no longer works for AutoCAD 2023.
vyankov
Thanks for everybody for help. Windows was the problem, i guess, after pre installation, i made a totally new installation of Autodesk and then, install the Autocad and Inventor. Now the software are working properly!
jamolkhasanov1983
Community Visitor
Community Visitor
Re: fatal error: unhandled delayload " AcWebView.dll" module not found at 90B74F38h
wasiu_21001698
Community Visitor
Community Visitor
Please how did you resolve the issue. I have tried to uninstall and re install several times. What do I do to windows to make my installation totally successful and usable? Thanks
