Failed to install Autocad2022
james981701
Observer Observer
james981701
Observer
Observer
Autocad cannot be installed
I think this is the problem in the setup log, but I don't know what it is Can you solve it?
2023-10-26T14:28:40.937 [Bootstrap: 5676, single] [Bootstrap ERROR] [ BS_Setup::ExecuteCommand ] => Process failed to launch. System exit code 2
2023-10-26T14:28:40.938 [Bootstrap: 5676, single] [Bootstrap ERROR] [ BS_Setup::ExecuteCommand ] => ERROR! The process executable cannot be found.
2023-10-26T14:28:40.938 [Bootstrap: 5676, single] [Bootstrap ERROR] [ BSData::initDat_ ] !=> BS_ERROR_305! Failed to download .dat file.
paullimapa
have you tried installing as another user with administrator rights?
what is your windows OS?
perhaps try installing latest acad 2024?
Paul Li
IT Specialist
@The Office
Valentin_CAD
@james981701 ,
Try the Installation & Licensing Forum.
Also, take a look at these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
mdavis22569
Try this full offline installer:
https://efulfillment.autodesk.com/NetSWDLD/2022/ACD/1E7D4EF7-A28E-3D3E-BA3C-C6FAE4AAB2E0/SFX/AutoCAD...
If fails, I'd be looking at the PC / Windows Profile etc..
Mike Davis
james981701
Observer
Observer
Thank you for your help
It seemed to work well, but when I installed it, it's still being preparing.
And the reason I'm trying the 2022 version is because Autocad 2024 also gets this error.
mdavis22569
 Installer / permissions:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Installation-error...
I would try and fine the EXE installer and the the "WEBINSTALLER" for the product.
Mike Davis
