Announcements
Exception in aecarchbase.dbx c0000027 happening with every drawing
kenn
Message 1 of 9
kenn
Every drawing that I open today I along with a few other users get the Exception in aecarchbase.dbx c0000027. I have run audit, purge and -purge R and no resolution to the problem. Fortunately, we are still able to work in and save our drawings.
We are using AutoCAD Architecture 2023 in a Windows 10 64-bit environment.
Any thought or suggestion are greatly appreciated.
Ken
Replies (8)
Message 2 of 9
mdavis22569
Hi @kenn
Do you have a support ticket in on this?
Also, any changes to the PC?
More than one PC doing this?
Mike Davis
Message 3 of 9
rushabhthakkar_910
@kenn, See if these help..!!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/exception-in-aecba...
And this, https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Exception-in-Aecba...
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 4 of 9
mdavis22569
I'd re-read what he posted and has done
And then your AKN which states:
Solution:
Try one of the following solutions:
He's done this ...
Mike Davis
Message 5 of 9
rushabhthakkar_910
I'd re-read what the article's say. Obviously I have gone through what OP said.
Bur what you said is not all that the article says. There a few other things to try as well.
Thanks and Regards,
Rushabh Thakkar.
Message 6 of 9
kenn
Being that we are using AutoCAD Architecture, I am very reluctant to import my drawing back in as a PDF import as I will lose all of the value of having AEC content.  I try the clean uninstall and reinstall within the next few days as I need to get a project completed before I do that step.
Ken
Message 7 of 9
mdavis22569
Maybe state that... give a more detail vs just googling and links.
Mike Davis
Message 8 of 9
kenn
I did submit a support ticket and we have (2) computers with the same problem starting at the same time.
Message 9 of 9
mdavis22569
Thought I saw it ..     I'd keep with ticket going too.
Also, make sure there weren't any recent updates on these PC's that could be causing it.
Mike Davis
