Errors during Nastran Sosftware Installation
carl
Message 1 of 11
carl
Hi All,
I'm curious if anyone else has seen this error during installation.
Carl
Replies (10)
Message 2 of 11
matthew.d
Hi @carl,
Welcome to the community!
Sorry to hear about the issue. This error can occur if the Hotfix, Service Pack, or 32/64 bit package does not match the version that is installed on the computer. Make sure you are using the right 64-bit package if that is what you have and try installing from the virtual agent. It may help to get more information about your setup.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 3 of 11
Mark.Lancaster
@carl
Most likely this issue is related to not having the crucial Windows updates for your operating system, so I would start there.  In addition NASTRAN software is not part of the Autodesk Virtual Agent.  Report back on your progress.
Mark Lancaster
Message 4 of 11
carl
Thanks for the tip.  I forgot that I had turned off Windows update.  Even after updating Windows 7, same error.
Carl
Message 5 of 11
Andrew.Sartorelli
Hi Carl,
Which service pack or hotfix for Nastran are you trying to install? I believe you just have Nastran standalone, but by chance do you also have Simulation Mechanical installed?
Andrew
Andrew Sartorelli - Autodesk GmbH
Message 6 of 11
carl
Hey Andrew,
I have the standalone version, and was trying to install Autodesk_NASTRAN_2017_11.1.1.240 .  Is this the correct package or should I be looking for something else ?
Carl
Message 7 of 11
Andrew.Sartorelli
Hi Carl, I'm at home at the moment on my personal laptop, so I don't have Nastran installed to check build numbers. But I believe 11.1.X should be the Nastran 2017 R1 release and 11.0 will be Nastran 2017. Do you already have Nastran 2017 installed on your machine? The 2017 R1 is just a patch that goes on top of the initial 2017 release. Regards, Andrew
Message 8 of 11
carl
I guess that's the rub.  For some reason, I assumed that DL was the install for 2017.  I'm running 2016 still.   I'd appreciate it if you could provide a link.
Carl
Message 9 of 11
Andrew.Sartorelli
Hi Carl,
If you're still on Nastran 2016 there will be a couple steps involved with getting 2017 operational.
  1. Generate a new network license file information
  2. Upgrade Network License Manager to 11.13
  3. Add new license file data to existing license file
  4. Download Nastran 2017
  5. Install Nastran 2017
  6. Install Nastran 2017 R1
You're still on Advanced Support, so if you have any questions about the process please don't hesitate to give us a call or schedule a call-back if there happens to be a phone queue. I'm sure one of my colleagues from Installation and Licensing would be glad to help you out!
I'm by no means a licensing expert just a FEA guy, so I'm sure if I've missed a step someone more knowledgable on the board will correct me 😄
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Message 10 of 11
Andrew.Sartorelli
Hi @carl,
Were you able to follow my suggested steps to successfully install Nastran 2017? If not and you still require assistance please let me know and I'll be glad to spin up a case for you with my colleagues in Installation and Licensing.
Andrew
Message 11 of 11
carl
Hi Andrew,
Thanks for the information.  I've been planning to update but still need to find the time to do it.  I'll certainly keep you posted.
Thanks again,
Carl
