error windows preferred path 〈systemdrive〉\programdata to store service data is
Hi all
While saving new nlm file i got this error in microsoft server 2012
error windows preferred path ⟨systemdrive⟩\programdata to store service data is
Mark.Lancaster
@Anonymous
@Anonymous wrote:
Hi all
What NLM file are you talking about?
Mark Lancaster
TravisNave
Sorry for the delay on the solution for this.  I have written an article that addresses this issue here:
https://forums.autodesk.com/t5/installation-licensing/lmtools-quot-windows-preferred-path-lt-systemd...
If your license manager is working, then you can safely ignore this message as it is simply a permissions warning.  If the NLM will not start because of this permissions issue, then my steps provided in the link above will address that.
Good Luck!
Autodesk Forums:
