Error while installing AutoCad 2017
- Mute
- Permalink
- Report
Hello everybody,
I recently tried to update my AutoCad 2012 to Autocad 2017 and tried to install Revit.
Before I did this i made sure to remove all the existing Autodesk files (https://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-p...
When I try to install the newer versions I get a Error which says:
ExecutableFileSettingsPage was not found in
c:\users\[myusername]\appdata\local\temp\_ai97e9.tmp\setup\acdeployui.dll!
the only thing I can do then is press OK and then the next error appears
Failed to load
c:\users\[myusername]\appdata\local\temp\_ai97e9.tmp\setup\acdeployui.dll (193)!
Then everything stops and disappears and nothing has been installed...
Can somebody please help me I really need AutoCad to word properly because I get refused in class when it's nog working
If the story isn't clear please tell me, English is not my first language and I will try to explain it better.
