Error compiling expression(JIT)
Everybody is good, my side to install CAD will be prompted to the components of the application of an unhandled exception happened (JIT), abnormal said there will be a prompt error under the compilation of expression, the create a new file or open the file, the command bar pops up some information about the error, enter a command will prompt out each time, including switching space, etc.In addition, I have tried to clear TEMP, reload NET, VC++, all of which are invalid, several of my computers are the same error.Is this a systematic error?What should I do? I don't want to reinstall the system, because I still have many applications on the system.Thank you very much!
natasha.l
Hello @Anonymous,
Thank you for posting.
This issue is related to incorrect registry entries pointing to the original \appdata\roaming\autodesk\autocadXXXX.
To fix this you will need to do some clean up. The registry key will vary depending on the version you are working with.
Delete the following registry key: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\XXXX
And the following folders:
C:\Users\<user>\AppData\Roaming\Autodesk\AutoCAD 20XX
C:\Users\<user>\AppData\Local\Autodesk\AutoCAD 20XX
Please also review the following:
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
What about CAD, which has been installed before? Do you want to delete this registry?I tried to delete the registry and files in the past, but nothing worked.Thank you for your answer.
natasha.l
Hello @Anonymous,
If you tried cleaning up the registry & it didn't work try a complete Clean Uninstall of the previous installation & use the MSfixitTool to complete it.
I tried using FIT to fix it, but it still didn't work
