Error 0xc000007b
Error 0xc000007b
Message 1 of 8
Error 0xc000007b
Well, I have just installed the new 3ds Max 2017, wich I don't thing has nothing to do with the problem, and as I open it, the following message is shown:  The Application was unable to start correctly (0xc000007b). Click OK to close the application.
It doesn't matter what I try, is always the same. I use this program to work, please help me.
Replies (7)
Message 2 of 8
natasha.l
Hello @Anonymous,
Sorry to hear you are encountering this error it is a common Windows related error typically when a 32-bit application tries to execute itself in a 64-bit system.
Please review this article.
https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/error-the-application-was-un...
Thank you for posting. Smiley Happy
Message 3 of 8
Darin.Green
@Anonymous,
The solution to this issue is here (of course fixing the newer version of c++ and Direct X). Start there then update this post with your results, not the referenced post.
If this information was helpful, please consider using the Accept Solution
Message 4 of 8
Dear Ma'm @natasha.l
How are you ?
I'm also having the same problem with 3Ds Max 2017 64 Bit in my laptop, completely installed perfect but when i click for launch it will give me this error [ 0xc000007b ] but Maya 2017 & Stingray 2017 works perfectly .
My System Configuration is :
Windows 10 64Bit
Core i7 2820QM
12GB Memory
2GB Nvidia Quadro 3000M
Hope I'll find here the best solution for my problem.
Thanks & Best Regards
Message 5 of 8
natasha.l
Hello @Anonymous,
Sorry, you are encountering this issue. Have you reviewed the information regarding Windows that is posted on this thread or the suggestion that @Darin.Green suggested about C++ & DirectX repair?
Please keep us informed on your progress.
Message 6 of 8
Hey,
Yes he was right Thanks @Darin.Green . Problem in my Visual C++ 2015 files i was used Directx Repair Tool and reinstalling my all visual c++ versions all version reinstalled successfully but only c++ 2015 having issue [fatal error 0x80070643] i was trying to repair my visual studio community 2015 but it was also failed. so i was clean reinstall my windows and tonight I'll try to Installing 3dx Max 2017 again hope it will done then ill post here my result.
Thanks Both of you Mr.@Darin.Green & Miss.@natasha.l for your support and guidance.
Message 7 of 8
natasha.l
Hello @Anonymous,
No problem. Thank you for keeping us posted on your progress. Smiley Happy
Message 8 of 8
Yahoo!! Now 3ds Max 2017 Working Perfect ..
