DWG TrueView as default program
Hi there,
Anyone an idea how I can configure DWG TrueView as the default program through Group Policies for Citrix environment? I've managed a way to pointing for DWG's to the .exe file, but it always gives the first time a short 'windows installer' popup.. so I'm looking for a better workaround.
Any help would be appreciated. Thanks!
Kind regards
mortild
Autodesk Support
Autodesk Support
Hi @Anonymous
Can you share a screenshot of the Setup window that comes up?  Perhaps check this article.
Davide Mortillaro
Senior Technical Support Specialist
Installation and Licensing YouTube Channel | Up&Ready Webinars
Hi there,
Thanks for taking your time to reply.
Hereby a screenshot from the installer that appears when opening Trueview, think this is not similar of your article where it happens on non-autodesk apps.
A file looks initially like this in File Explorer; dwg_auto_file.
Thanks!
mortild
Autodesk Support
Autodesk Support
Hi @Anonymous
The dialog usually comes up when the software tries to set up the user folders (%appdata% and %localappdata%) for the first time. This happens only on first launch, subsequent launches do not trigger that.
I have seen this in the past with AutoCAD as well (DWG Trueview is based on it) in conjunction with Active Directory. See if this article helps: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Secondary-installer-comes-up-with-every-launch-after-user-profile-deleted.html
Also make sure that the user has R/W permissions on the below key and corresponding sub-key:
HKEY_CURRENT_USER\Software\Autodesk\
Davide Mortillaro
Thank you, I see this folders were excluded in the profile from Citrix, will try this out and see if this is the solution.
Enjoy your day!
