Creating Powershell script for bulk uninstall
Hi There,
i am requested to remove all trace of existing Autodesk products on my company , the installation made were anarchic without control so what exist is unknown.
We have SCCM in place and my plan is to create a powershell script which look after all products with publisher = Autodesk , isolate the uninstallStrings , arrange it to be silent and ran it , i made a first script and it works like a charm against one suite i did install for test purposes
what i noticed is , alternatively , for this specific suite (Inventor LT 2015) , instead of running all that uninstall strings (can be msiexec /X or setup /P /Q) , i can isolate the GUID (present on HKLM\Software\....\Uninstall (and on the other with WoW6432Node)) which represent a MSI product then ran msiexec /X against all of them
Second approach like a charm but is valid ONLY if all the components of Autodesk are MSI , that avoid me to manage any other uninstallstrings which are not msiexec
make sense ?
so my question is to know if , historically , ALL the Autodesk products are MSI ?
Hoping i make sense
Rgds,
david.lau
Create a deployment of Inventor LT 2016.  In the deployment folder, there are unisntall scipts for SCCM.
David Lau
Hi David , Inventor 2015 was an example , i need to uninstall more than 300 autodesk registered softwares from more than 1K computers.
Is anyone can confirm me that Autodesk only use windows installer technology to install their products ?
XT
m_latz
Just  one additional hint.
You write "... look after all products with publisher = Autodesk , ... "
But you have also 3rd party programs installed with Autodesk products, were the publisher is not Autodesk.
i.e.:
"Eco Materials Adviser for Autodesk Inventor 2013" from publisher "Granta Design Limited"
"FARO LS X.X.XXX.XX" from publisher "FARO scanner Production"
regards
Markus
if install was proper then those products should be uninstalled per uninstallation of parent software (maybe not via msiexec but from setup.exe)
i noticed that setup.exe actually triggers msi install (and uninstall) in the backend
but thanks for this information , i will add a second check on querying *autodesk* on DisplayName , this should not hurt ...
Rgds,
XT
david.lau
We are using MSI technology to install software.
David Lau
You wouldnt happen to be able to share this uninstall script of yours?
