COMPUTER CRASH - NEW COMPUTER AND ACAD 2021 - NEED TO REACTIVATE
RAFUSE
RAFUSE
I am a consulting engineer, sole proprietor, one man shop.  My work computer big time crashed and would not boot.  After much painful attempting to revive it I was forced to purchase a new computer.  I first bought acad in the mid 1980's and continued to feed the beast much $$ over the years.
I have a perpetual  license.   I installed the 2021 version and have been using it since.  I have many canonizations on it.  I did manage to recover the hard drive files and programs.   I used a program that transferred all my files, programs, settings, etc. to the new computer.  The program worked beautifully!  However, my auto cad programs now require reactivation!!!
Who do I need to contact in Autodesk to get help???
My business obviously depends on ACAD and I need to get it working!  Quickly, I am dead in the water.
HELP!!!
pendean
Community Legend
Community Legend
@RAFUSE So you just need to activate the program, yes? Just login when you start the program using your Autodesk Account that is tied to your perpetual license and it will be activated.
Do you still have access to your Autodesk Account that the license was purchased with? That is going to be a requirement.
On a side note: do you have the last update for AutoCAD 2021 installed? It's this one
https://help.autodesk.com/view/ACD/2021/ENU/?guid=AUTOCAD_2021_1_4_FIXED_ISSUES#:~:text=SHARE-,2021....
RAFUSE
I am unable to access my account with Autodesk, likely since it's been "so long".
I do have the original ACAD 2021 installation file I downloaded in 2020.  I ran Autocad and it spit this out.
Not eligible for online activation
Your product cannot be activated online due to one or more of the following reasons:
  • The product version you are trying to activate is not available under the license for your upgraded product.
  • Your subscription has expired.
  • You are not using the most up-to-date serial number.
To get help, Contact Customer Support to submit a case.
(Click Activation Codes and Request Codes > Activation & Registration Support.)
(Error 46)
RAFUSE
My license was perpetual.
pendean
Community Legend
Community Legend
That's going to be a big problem, not sure anyone here in these forums can give you a hall pass to activate your software. Sorry.
You could try this from Autodesk
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-request-an-...
And sadly cannot and run any older or newer version as a fix either, a perpetual license means you get no other option for free.
RAFUSE
They actually got my ACAD back up and runnint.
I am impressed!!
mari.shimode
Hi @RAFUSE, I believe your issue has been solved maybe by contacting our support. I have marked @pendean's reply as an accepted solution to close this topic as the information may be useful for the community who has a similar issue. Please visit the Autodesk Community if you have any other questions in the future.
Mari Shimode
