Compatibility Windows Server 2016
I Would like to migrate the Windows Server to Windows Server 2016 on which the autodesk components are installed.
I would like to know if autodesk softwares support  Windows Server 2016 and virtual server on windows server hyper-V 2016.
Thanks you
leowarren34
Hi @Anonymous,
A couple of things:
Virtualization depends on you having the correct license type to remain within the EULA: https://customersuccess.autodesk.com/articles/setting-the-record-straight-can-i-virtualize-my-autodesk-software
It also depends on what products you plan to run on the server since many products aren't compatible/certified with Windows server - what are you planning to run and which versions?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
system requirements are always posted on autodesks website here: https://knowledge.autodesk.com/support/system-requirements
Thanks for your quick answer.
Normaly, the product is :
Autodesk Network License Manager (LMTools)
Now can I move it to a virtual windows server 2016 in hyper-v hypervisor environnment?
Will it be compatible with?
Thanks again
