Command Window Repeatedly Opens and Closes when I Launch Revit
slukesX5VSY
slukesX5VSY
I downloaded Revit 2022 for a class (the professor specifies that it MUST be Revit 2022), and I successfully installed it. However, when I launch Revit, a Windows command window begins to repeatedly open and close. It does this endlessly when I have Revit open, making it functionally impossible to run Revit. I clicked on one before it was able to close itself, and attached an image of what the command window says. Any help on how to fix this? I already uninstalled and reinstalled Revit, only to have the same issue. I need Revit to work soon so I can begin my classwork.
Simon_Weel
Doing a quick search on the error message turns up a lot of hits for an un-activated Windows installation.
mdavis22569
Hi @slukesX5VSY
Can you have a look at the following article and see if it helps
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/SQLDUMPER-EXE-wind...
Mike Davis
