Clean-up Utility for Autodesk
Hi there. I need a Clean-up Utility for Autodesk products and Maya. Is one available or a way to perform one ? Cheers.
Mark.Lancaster
@Anonymous
Perform a clean uninstall per these instructions:  Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine that you need to leave as is (and not remove them).
If you have Windows 7 or 8/8.1 use Microsoft Fixit. With Fixit you need to run it for each application that you need to uninstall
For Windows 10, use the Microsoft Cleanup Utility.
In my signature are the links to these applications.
Mark Lancaster
